RATIO
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gerardo1961, Jul 4, 2010.
  1. theburren
    theburren Bobtail Member
    15
    Apr 22, 2012
    Conway, SC
    I was hoping someone could answer a question.
    What would be viable rear gears for a CAT CT660 15L tractor running 11R24.5 tires and 4.30 rears, in order to get the best fuel mileage I can, and still keep as much pulling power as possible?
    It will be used for light loads (10K to 40K, usually in the 20K range), running 400 mile daily round trips on relatively flat roads with small hills, and speed limits ranging between 45 and 70 mph.
    I have an '01 Pete 387 with 336 rears and stage 1 PDI tuned 6NZ motor which averages ~ 6.3 mpg running hard up to 72 mph (72 on flat lands will tac at 1500-1600 rpm).
    Thanks in advance for any help.
    ***Sorry, the CAT has an 18-Speed Manual, With Double Overdrive & Double-Lo
  3. Cat sdp
    Cat sdp . .
    21,322
    76,372
    Apr 8, 2012
    Orion's Belt
    Sorry to be negative but that's the wrong truck for the work you described...... And the 660 is a pos.
    P.S. Most guys are going >3.55
    BigshotBob and dustinbrock Thank this.
  4. theburren
    15
    Apr 22, 2012
    Conway, SC
    Most guys are going with 3.55 when? With work similar to mine?
    I would love to keep the 4.30 rears for next year when I start hauling timber, but I just don't want to be burning an extra $1200 in fuel per month until that happens.
    I was thinking of 3.70 or even 3.90 as a nice compromise...
    Thanks for your thoughts on the 660. It looks OK to me.
  5. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    3:55 are the rears you want man. The work your describing with an 18 spd is a great set-up for 3:55's. The 18spd will give you all the low end you need for hauling timber. If you didn't have all those gears on the low side, 3:90's would be better. But the 18spd trans was built to give guys low end gears with the same overall drive of .73 same as the 13 spd to get best fuel mileage on highway as well.
  6. theburren
    15
    Apr 22, 2012
    Conway, SC
    Thats what I was thinking, thanks.
    I'll be under 90K gross with the timber so nothing too insane.
    I was also considering the 3.70, the more I look at it, but not sure yet....
    THoughts?
  7. Largecar359
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    3:55 and 3:70 are pretty similar. I think either way you go will be fine. 3:55 are gonna put you at 74 mph at 1500 Rpm. 3:70 will put you a lil slower. Both are gonna pull great.
  8. theburren
    15
    Apr 22, 2012
    Conway, SC
    Thanks for the input.
    I'll probably just go with the 3.55 and depending on what the core charge is, ask to keep the 430 rears...
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Only advantage to the 430 is when you let the clutch out in low gear on a very hard pull ,otherwise 3.55 or :3.70 will do fine once rolling due the to 18 speed besides the 430 gear will run outta it's rpm range by 60 mph 430 was fine with mechanical engines screaming at 2000 rpm not so hot with new engines though
  10. theburren
    15
    Apr 22, 2012
    Conway, SC
    Yea, I sometimes wish I knew how to work on those old mechanicals...
  11. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    my t600 with 3.70 and 10 sp has 3.70 and gets 5.7 mpg.
