Rattling noise under hood - 98 Freightliner cat c12
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Abbctrucker, Aug 29, 2020.
  1. Abbctrucker
    Abbctrucker Bobtail Member
    So here is what happened
    I didn’t realize the truck had low engine oil in it (yes stupid me I should have checked it before), and realized a rattling noise being on higher rpm. So topped up the oil and it’s good now. But the rattling noise is staying. Usually happens on higher gears and higher rpm. When I drive 50-60 mph, I realized when I touch the clutch down just a soft touch down, the rattling noise goes away. There is no noise being in neutral and parked.
    Then again, I just fixed a leak on the exhaust under the hood and to be honest the guy did a horrible job welding it which I would like to get re-done anyways.
    what could be my problem here. Any help is much appreciated!
  3. AModelCat
    159,412
    How low is low? If it was only a gallon or 2 low I doubt you did any damage.
    Light touch on the clutch pedal and it goes away? I'm betting on the clutch release bearing. Pump a few shots of grease into it and see what that does.
    magoo68 and spsauerland Thank this.
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Find your or go buy you a big grease gun and buy a 1 or 2 ft. flex tube and put it on end of it, and grease the throw out bearing you may have to take sq. plate off if you do not see a tube to put grease in sticking down out of plate, grab the fan blade with eng. hot but off to see if it moves at all back and forth at all it can make noise before it comes apart and can hit rad.,
    AModelCat Thanks this.
