Rattling sound coming from the engine.
Discussion in 'International Forum' started by texasmorrell, Feb 27, 2015.
  1. texasmorrell
    texasmorrell Medium Load Member
    597
    625
    May 3, 2012
    Lone Star State
    My truck started making a rattling sound. It's coming from the front near the engine fan. I only hear it when it's idling. I've heard other trucks making that same rattling sound before. Anybody give me an idea what it is?
  3. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
  4. C-WALSH
    C-WALSH Bobtail Member
    34
    41
    Oct 4, 2014
    What make of engine, mileage? Could be fan clutch, worn bushings on accessory gear, bull gear, blown/worn/loose front motor mounts, etc, etc...
  5. texasmorrell
    597
    625
    May 3, 2012
    Lone Star State
    2nd Gen ISX on a 09 Prostar 730k miles.
  6. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    Does it change at all when the air compressor is pumping?
  7. Riprap
    Riprap Light Load Member
    286
    1,979
    May 31, 2014
    Saginaw, MI
    ^ what they said.
    Have you turned motor off and tried to see if the fan is wobbily? Mine was when the fan clutch was shot.
    Also does the noise come and go where it could be your air compressor when it cycles?
  8. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    keep it simple check the fan clutch first, lots of luck
  9. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    What about the idler pulley/tensioner?
  10. texasmorrell
    597
    625
    May 3, 2012
    Lone Star State
    The sound does come and go. I dumped my air while I was idling to make the air compressor kick on. The sound was not there. Right now my truck sounds normal. The rattling is not there. But I'm sure it will return.
  11. ArsonLarson
    ArsonLarson Bobtail Member
    7
    I had a similar noise on a '12 ISX in a W900 two years ago. One of the belt idler tension pulleys had to be replaced (under warranty of course). Could be your same issue.?.?.?
