Re Coil air lines???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MTMAUS, Oct 29, 2020.
  1. MTMAUS
    MTMAUS Light Load Member
    181
    151
    Sep 28, 2019
    One of my drivers forgot to disconnect his airlines from the trailer (in Australia we call them suzie coils) and all of the coil and spring in the air lines is all over the shop.
    Anyone have any tricks in how to maybe get them back to something passable? I was think maybe trying to wrap them around a cylinder or something and leave them for a bit.
    Any suggestions would be great.
    thanks
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,193
    6,011
    Aug 26, 2014
    Figure the springs are trash. In a bind might be able to put a new ends on the line and hook them back up.
    Hook some bungie cords or some thing to them keeping them from harms way. Get the job done and put it back like it was.
    Old school was 3/8's rubber hose hooked up that way.
  4. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    Look around the shop , you might find a collor and sleeve off an old one
  5. 201
    201 Road Train Member
    11,310
    22,926
    Apr 16, 2014
    high plains colorado
    Coil lines are junk. I'd go with the rubber lines and that big spring that holds them up. I've seen ( ahem) guys forget their lines and the rubber ones work a lot better, especially in the cold.
    Cattleman84 Thanks this.
  6. '88K100
    '88K100 Road Train Member
    1,157
    2,395
    Aug 23, 2020
    Coil lines don't have memory,,just replace them. We only use rubber lines so if the driver forgets to remove glad-hands either their is no damage or the air line flies back and takes out the rear window,,,twice our village idiot did that this year
    650cat425 Thanks this.
  7. little cat 500
    1,950
    1,004
    Jan 17, 2010
    Abbottstown PA
    there like 20 bucks apiece pitch them
  8. 201
    11,310
    22,926
    Apr 16, 2014
    Light cords don't do well in that situation either,,,
