RE: Dock walk
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Powell-Peralta, Jun 6, 2009.
  1. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    What's happened is we have just got brand new trailers. These (utility) trailers have, apparently, automatic air deflation when you park them (pull the red valve).
    What happens is that the trailer height will go down but also it will move foward leaving a gap between the back of the trailer and the dock.
    How can we prevent this?
  3. Biscuit75
    Biscuit75 Road Train Member
    Only thing to do is to slide the tandems all the way to the rear to prevent the sag and forward movement. It will also keep the floor height even with most docks.
  4. Chain Drive
    Chain Drive Medium Load Member
    436
    113
    Nov 28, 2008
    Nova Scotia,Canada
    If you have a manual dump valve dump the air before you back in. My wagon did the same thing only opposite if the air was dumped, it would re-inflate when I push the button in, anywho if you don't have a dump valve put one in (pretty simple, just a ball valve and some connections)
  5. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    just what I was going to say
  6. 7mouths2feed
    7mouths2feed "Family Man"
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    More info on the dump valve please? I need to have one in mine but not sure how to do it. I know a valve to dump the air but how do I cut off the incoming air? Since all the air bags are filled from the same source I considered a normally open air solenoid for the incoming and a normally closed for the air release wired to the same switch. When activated the would go opposite of normal position closing incoming air and opening the release valve. Does this sound right? Simpler sytems ideas more than welcome. Thanks
  7. Chain Drive
    436
    113
    Nov 28, 2008
    Nova Scotia,Canada
    forget all the fancy electrical stuff. I will take a closer look at some of our wagons, some have a factory valve and some just have a ball valve "t"ed into the supply to the bags
    7mouths2feed Thanks this.
  8. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    I assumed every new van/reefer came with the anti-dock walk suspension like Hendricksons Surelok. A manual dump would solve you problem. Some leveling valves have a manual dump option which is air operated.
  9. Powell-Peralta
    1,585
    240
    Jul 17, 2007
    i forgot to mention that we don't have manual valves and it's not actually the lower floor level that is the problem. It's the gap between the back of the tralier and the dock door---the warehouse personel get a little nervous over this. The dockplate still can reach, but you can see air in between the trlr and the dock and i think this makes the dockhands nervous.
  10. Chain Drive
    436
    113
    Nov 28, 2008
    Nova Scotia,Canada
    I knew what you meant my wagon does the same thing, we use hydrolic dumpers to lift our trailers vertically to unload the wood chips and if you are not hard against the bumper the trailer will slide back and bend the legs (you don't want to make that call to the boss) anywho the air has to be dumped before we dump, and my wagon walks ahead about 8" so I dump the air before I back in all the way, that way when I bump the stoppers I stay there, long story short you need to override the auto dump or install some sort of manual dump
  11. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    How does slidding tandems all the way back prevent dockwalk??
    my 07 Great Dane would walk slightly no matter where the tandems were.
    Hendrickson susp without auto dump. I installed manual dump valve and of course no more movement
