For the local driver whos asked about local logs:
If you drive under a 100 mile radius each day you do NOT
have to keep a logbook.
Generally you fill out a form verifying that you worked
under 12 hours and stayed within a 100 miles.
However, say you ran 300 miles one day and 200 miles the
next you must keep a log for that entire 7 day period.
Even if you went back to driving under 100 miles the rest of the week.
You can't jump back & forth between methods of record keeping
during the same 7 day period.
It's one way or the other.
DOT will notice any such gaps in your logbook if you don't.
And the DOT don't like any gaps.
So, if you run less than 100 mile radius< 12 hrs. all week do the form.
If you go beyond 100 miles radius anytime during your week do a log
for that entire week.
Be smart, play it safe.
re: local logs
Discussion in 'Questions From New Drivers' started by prime rib, Dec 12, 2010.
The other thing is just a clarification - the 100 mile radius is air miles and not road miles. Silly when you consider we're driving on roads not flying through the air but the 100 mile radius is indeed measured by air miles and not driving on the road miles. I learned this a few years ago when I was a P&D driver here at Con-way. I would drive 135 miles one way to my furthest stop and did not have to fill out a log whereas another driver that had 125 to his did - draw a 100 mile circle from my terminal I was in it and he was not. I questioned it and received an email from Con-way safety with the 100 mile short-haul exemption pasted into it and it is indeed air miles..
You are indeed 100% correct that a log needs to filled out for the next week if you exceed the 100 mile radius - actually the next 7 days, not week.. We are required to complete the entire month if there are more than 7 total remaining - if less than 7, we must complete the following month also but that is simply company policy..Last edited: Dec 12, 2010
Its 100 air miles !!
For all of those confused by the 100 mile exemption here's the link straight from the DOT..
http://www.fmcsa.dot.gov/rules-regulations/truck/driver/hos/hos-faqs.asp#_Toc111021236 -
As a local driver, your company can require you to log. Then you must.
Rerun8963 Thanks this. -
The logical reason for it being air miles instead of road miles is to standardize how far x miles takes you. You can take a place that's 70 road miles down the interstate and easily find another route that would be 120 road miles. Thus opening up debates on if you're really past your 100 miles or not. With air miles, it's a hard line, no confusion available.
Your time keeping for the 100 mile rule can also be a time card. You must report how the carrier says but a time card is legal if the carrier allows it.
good times
Log hauling, well, that's a big gamble job like construction but the down time could last a lot longer if mill's stop production for any reason or stop receiving because demand has dropped and could last for week's. I thought about doing it myself but got turned off real quik when I started learning about the down sides to it.
