Reading Qualcomm
Discussion in 'Swift' started by bwajla, Oct 12, 2012.
  1. bwajla
    bwajla Light Load Member
    100
    24
    Apr 13, 2010
    Jacksonville, Florida
    I'm trying to get back into the swing of things around here. They sent me a load then turned around and sent me a removal of next load notification. Does that mean they took the load off me?? Thanks ill eventually figure this thing out
  3. bwajla
    100
    24
    Apr 13, 2010
    While I'm at. What's a d3 trailer? I'm assuming dura plate but I'm guessing. How the heck u tell which r which. They really should have sent me with a mentor this is all overwhelming.
  4. Balakov100
    Balakov100 Road Train Member
    3,937
    2,636
    May 10, 2012
    Temple, TX
    Swift has a bad habit of sending the same load to multiple Trucks.
    Unless it's a crappy load.
    If that happens somebody else might have accepted it first, so it comes off you automatically.
    'Most' of the Trailers are Duraplates.
    MS Carrier Trailers aren't Duraplate and some of the other OLD POS Trailers aren't.
    bwajla Thanks this.
  5. inkeper
    inkeper Road Train Member
    1,440
    1,059
    Jan 30, 2011
    Texas
    Most of our trailers are made by Wabash and they will have duraplate on them in several places. The few Great Dane and another brand I can't think of right now are always duraplate type trailers. If the inside walls have wood on them they are not duraplate.
    Just an FYI... trailers that begin with 14xxxx are 14 feet tall and can only be used in the western half of the country, there should be a map on the nose that will explain. Also trailer numbers beginning with 75xxxx are 57 feet long and are also restricted as to where they can be. They have taken some 57s and cut them down to 53 footers, they will begin with 73xxxx.
    bwajla Thanks this.
