Real Life Fuel Milage
Discussion in 'Trucks [ Eighteen Wheelers ]' started by BrettR, Sep 23, 2014.
  1. BrettR
    BrettR Bobtail Member
    14
    Jun 1, 2011
    Looking to upgrade a few trucks that are getting some miles on them.
    I have avoided the high emission trucks to this point.
    Our MPG's are getting pretty low and need to run the numbers on some newer equipment.
    Would like your real time, not hear say please, mileage of '10, '11, '12 Pete 386 or KW 660.
    We do not need new trucks, 400K-500K used trucks will serve us well, just trying to find a happy medium.
    Thanks to all, Brett
  3. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    8.44 mpg real life ; since august 2nd I uploaded every fueling receipt data on this site from pump to pump.
    My truck Volvo 780/ D13 2008/ 1,362,000 miles(team) original motor, (except cam and injectors; ) real mpg includes idling, regen fuel.
    https://mygauges.com/gauges/fuel
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Do a ECM download give. 10 % plus/minus on what it reads .... Don't go by what someone driving 55mph says unless your drivers care the same as a owner op ... Download will also show emission faults as well if it shows a lot of faults move on to next truck
  5. BrettR
    14
    Jun 1, 2011
    Thinks for the input.
  6. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    what do you haul, van, flat, tanker??
  7. russtrucker
    russtrucker Road Train Member
    1,767
    337
    Mar 27, 2012
    Central PA
    my friend's 2015 prostar with isx450, 10 sp ultrashift, and gets 9 mpg driving 70.
    skro47 Thanks this.
  8. Toomanybikes
    Toomanybikes Road Train Member
    2,422
    3,285
    Apr 8, 2009
    Well some are going to get their panties all wadded up but most fuel numbers you hear from drivers are false. Most read the in dash Lie-o-Meter or the qualcom crap of which inflate the mpg in order for the manufacture to advertise their product. Some drivers add a MPG or two to impress others of there supertrucker status.
    I am in a fleet of about 30 newer trucks. All 2012 up to brand new 2014. Mostly KW and Petes with the new 680's as my favorites. Some Cascadias. Some detroits, but mostly cummings and paccar. Fleet spec rears (–3.50) and everything from 9 - 18 speeds.
    Every day with some 60+ drivers slip seating all pulling the same load around 100K we all get the roughly the same 5.5mpg. That is the same as we got last year too. The few prostars and the maxforces we had last year got no different.
    I do look at all the fuel numbers, all the miles, and all the fill ups. We keep track of everything. It is by far more consistant then I expected and no where near the crap I hear from the supertruckers with their BS 8,9, and 10mpg.
  9. SpankingGT
    SpankingGT Light Load Member
    253
    55
    Sep 9, 2010
    2004 Freightliner columbia.
    1.18 million miles- all original.
    13 speed-2.93 rear end ratio.
    22.5 low pro tires.
    Average speed 72 mph
    Loads always over 73k gross
    Traveling distance- 2773 miles ( dedicated run )
    AVG MPG- 6.09
  10. CO2kmax
    CO2kmax Bobtail Member
    12
    6
    Sep 29, 2013
    Denver, CO
    I just bought a 2015 Volvo 780XE with the D13 2.64 rear end. I drive 60mph average heavy weight is 72k. I have a TRIpac so I don't idle. The engine only has 22k miles. First full month MPG was 7.07 and second full month was 7.12. I calculate in a spread sheet not the truck.
  11. ipogsd
    ipogsd Heavy Load Member
    977
    515
    Jun 13, 2012
    2013 Cascadia, DD15, 10 speed, 3.42 rears, No APU. 2 quarter IFTA was 7.98, I'd guess about 20k average load in n dry van.
