Really Jammed up Bad! 25K paperweight Cummins ISX Replacement
Discussion in 'Trucks [ Eighteen Wheelers ]' started by newskate, May 27, 2024.
  1. newskate
    newskate Bobtail Member
    42
    13
    Jun 13, 2012
    Hello new poster I am hoping someone can help me with some knowledge!
    I replaced my 2015 400 hp Cummins isx with a rebuilt 2015 450 hp Cummins isx. Unfortunately, I cannot get the truck to communicate with the engine! Come to find out that the 2015 engine is actually a EPA 2016 build. right now the ecm for new engine will not communicate with the truck and the ecm from the old engine will not recognize the engine. Both ecms run the engine. I spent 3000 dollars at freightliner after installing the engine only for them to suggest that I take out the new engine and get a different one. I did learn that the communication baud rates are different, with 2015 engines communicating at 250k baud rate and 2016 communicating at 500k baud rate. I had Cummins change the setting on the new ecm for 250K baud rate... but the truck still will not recognize the engine and I get no gauges or lights. I Got a very expensive paperweight! Is it possible that i need to do something with the CPC4 chassis module? I did check with Cummins and the engine harness is identical for both years. I need some suggestions or information on where i can go from here do i have to convert the engine somehow back to 2015 specs? I am lost.... I spent 25K and have nothing to show for it.... both the engine installer and freightliner are unable to help. Any ideas? Truck is located in Boise Idaho.
  3. 062
    062 Road Train Member
    6,276
    33,783
    Oct 20, 2013
    Oxbow, Siinman and gentleroger Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    Please provide truck info and ESN’s for old and new engines.
    Do you still have the ECM from the original engine?
    Oxbow, Bean Jr., 062 and 3 others Thank this.
  5. Siinman
    Siinman Road Train Member
    5,436
    13,974
    Mar 5, 2017
    Kansas City, MO.
    Not sure if you can check with Pittsburg power. I think they do stuff with the ECM and such. I have never used them but heard them talk about it a time or two. Sure lots of people hate them as well but just a suggestion.
  6. AModelCat
    161,302
    The base engine is the same though is it not? Same sensors, actuators etc?
  7. Diesel Dave
    9,249
    29,588
    Jan 20, 2010
    Hesperia, Ca.
    My 2014 Pete ISX 15 had a recon dropped in on 2016. Cummins dealer did the swap. I bought it in 2020. Runs flawlessly since I had it.
    Siinman Thanks this.
  8. Deezl Smoke
    Deezl Smoke Medium Load Member
    517
    338
    Feb 12, 2011
    Hillsboro Oregon
    Even though the connections couple together, is there a chance the pin layout is slightly different?
    Oxbow, Siinman and AModelCat Thank this.
  9. AModelCat
    161,302
    That's the only thing I can really think of.
    Oxbow and Siinman Thank this.
  10. newskate
    42
    13
    Jun 13, 2012
    Ok if it is a pin difference can anyone tell me where I can get a pin schematic I have vins for both trucks the one the engine came out is also a 2016 cascadia 1fujglbg9hljf0974 the engine went into a 2016 cascadia vin 3akjglbg6gshf6206 can anyone look these vins up and tell me if their is a difference?
  11. newskate
    42
    13
    Jun 13, 2012
    According to a vin decoder the engine came out of a 2017 cascadia and I am putting it into a 2016 cascadia I don’t understand why it won’t communicate!
