Rear Bunk cigarette lighter not working?
Discussion in 'Experienced Truckers' Advice' started by Manny2016, Sep 12, 2016.
  1. Manny2016
    Manny2016 Bobtail Member
    6
    so i drive a 2012 KW T700, my bunk cigarette lighter stopped working awhile ago, im having a hard time locating the fuse (if any for the bunk lighter), anyone having the same issues? Thanks in advance
  3. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    May be the fuse maybe not.Could be the $10 screw in receptacle itself bad,didnt pop out & overheated the coil,2 wires that plug into it,corroded connection,or melted.JMO
    Manny2016 Thanks this.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,667
    18,430
    Nov 1, 2010
    Burnsville, MN
    Have you checked in the owners manual for the truck?
    It will have the fuse layout and say where the fuses are located.
    By the way, it is a 12V outlet - not a cigarette lighter.
    The lighter is what plugs in to the 12V outlet.
    Manny2016, Starboyjim and G13Tomcat Thank this.
  5. G13Tomcat
    G13Tomcat Road Train Member
    11,872
    42,142
    Jun 7, 2011
    Cigarette lighters in 12v outlets are so outdated. . so maybe its the actual "lighter" you are trying to use in the 12v outlet that's actually bad????
  6. snowwy
    snowwy Road Train Member
    20,546
    13,281
    Jul 6, 2009
    Could try using a new lighter. They're fairly cheap.
    As for the socket itself. Is it just the one or others also. On my FL for instance. They were all on the same circuit. By the time the truck went by by. NONE of them would charge my phones. But i was able to still use an invertor for ac electricity. Running the printer was a no go though.
  7. Toomanybikes
    Toomanybikes Road Train Member
    2,360
    3,120
    Apr 8, 2009
    Quit smoking in bed.
    bzinger and lagbrosdetmi Thank this.
  8. TripleSix
    129,711
    It's probably under the bunk. Or remove the panel. Also, use a tester and make sure youre getting power. If you are, replace the socket.
  9. tscottme
    tscottme Road Train Member
    I had a bunk power outlet which shared a fuse with the power outlet on the dash also have an inline fuse about 2 inches from the bunk outlet, buried under the plastic the power outlet was mounted in. Crazy.
    TripleSix Thanks this.
  10. Crazytrucker77
    Crazytrucker77 Heavy Load Member
    848
    1,048
    Nov 23, 2014
    Grants Pass, OR
    Usually there is a small panel of fuses in the control panel in the bunk area. Call you maintenance people and ask where the fuse panel is. According to Google the fuse box is behind the panel behind the glove box
    tscottme and TripleSix Thank this.
