Hi
I recently bought a 2015 volvo 670 xe package with 425hp .to my surprise the rear differential axles didn't come with temperature sensors .so do u know if i can have them installed and programed this way it will show on the dash gauges ? Another question is the hill assist feature something i can add to the i-shift .
Thank you all .
Rear differential axles temp sensors
Discussion in 'Experienced Truckers' Advice' started by warrior12345, Oct 10, 2018.
Page 1 of 3
There should be an extra plug on the pumpkin for a sensor, you would need to install separate gauges for each of them.
Lepton1 and warrior12345 Thank this. -
Dont waste your time. Unless you just like watching needles move there is no point. With 425hp your rears will never get hot enough to worrie about.
KB3MMX, Final Drive, Diesel Dave and 2 others Thank this. -
If worried get a temperature gun and check temps after a good pull.. it’s useful for checking hubs too
Opendeckin, KB3MMX, 86scotty and 1 other person Thank this. -
I wonder how accurate that would be ?KB3MMX Thanks this.
How does horsepower affect the rear temps? I've got a 550hp truck that doesn't go above 170 on either differential. I've also got a 2.8L Duramax that has hit 260F climbing mountains with a load.KB3MMX Thanks this.
A 2.8L Duramax. When did that come to market?Opendeckin Thanks this.
Its porportionat.
Your truck at the very least is going to have 40;000 rears . Industry standard.
With 425 hp and I'm guessing 1650 torque at the most there not going to get hot. With your specs I'm perty certain you'll never going to gross over 80,000 ever. So yes it's not going to matter much. -
I think like 2016 on the Canyon and Colorado. I've got a 2018 Colorado and the engine temperature doesn't even get above 190F no matter what I do. But the transmission temperatures go crazy once I put like 4000 or more behind it and start climbing grades. It's the opposite of how my Volvo with 550hp and 3.08 rears acts. The engine temperature gets upwards of 240F on extended pulls at full throttle, while the rears don't pass 170F.
I think the Colorado has 3.42 rears.spindrift Thanks this.
Page 1 of 3
