Rear differential input seal replacement on 93 t800
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Nestor, Feb 26, 2018.
  1. Nestor
    Nestor Light Load Member
    160
    23
    Oct 21, 2015
    Hi good afternoon . Anybody can give me some tips or help me . I’m getting ready to change seal on the rear differential on a tandem axle. I believe it’s called the input seal.
  3. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    First question - Do you have the proper tools? I did my own and had to borrow tools to do it, iirc it's at least a 3/4 drive, 2 5/16 socket (depending on your rear ends).
    Unless you want the satisfaction of "doing it yourself", you're time and money ahead by paying a shop.
  4. Nestor
    160
    23
    Oct 21, 2015
    Yes I do have tools . I’m pretty mechanically inclined
  5. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    3/4 inch impact . A good one.
    Or 1" impact is better.
    Big socket selection 2" and up.
    Sometimes those yolks can be a bugger to get off the input shaft if it has been on there long time. You might need a puller if you can't beat it off with a hammer.
    Other then that perty straight forward.
    I ussally replace the yolk , nut and U joint with new if it' been on there long time. Seal surface will have big groove in it.
  6. AModelCat
    161,291
    I'd get a spare u-joint too. I've had a few where the caps are seized in and it needs to be torched out. Had others that had the trunnion blow clean through the end of the cap. May even get it out and find the u-joint is worn out or the needles have brinelled (beaten in) the trunnion ends.
  7. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    Sure. Always check the axle vent to be clear or replace it whenever replacing a differential seal. If it is plugged you'll be replacing it again in short order. Inspect the yoke carefully for a seal groove worn in and replace if worn. I like to install a new yoke nut, or at least red loctite the old one upon install.
    BoxCarKidd and Klleetrucking Thank this.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,517
    6,576
    Aug 26, 2014
    All of the previous are good points but I will add a couple.
    1: If the yoke has side play tighten the nut first and see if it tightens up. If it does not shims need to be removed.
    2: Get that outer bearing out and look at all you can see for condition.
    3: There are dial indicator measurements and such but a field fix is chuck a thin shim and put the yoke on with the old nut. If it still has slack remove a bit more. When the slack is gone put the new seal in and install yoke with new nut. They are considered a one use item.
    4: Wear rings ( speedy sleeves ) are also available. They do a good job of repairing damaged yokes if properly installed. Some of them require a different seal.
