Rear discharge Vs Center Discharge with pipe to rear.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Isxrookie, Dec 5, 2021.
  1. Isxrookie
    Isxrookie Light Load Member
    82
    46
    Jan 24, 2011
    New Orleans, la
    Looking at a tanker trailer to buy. It’s a center discharge with pipe to rear. Is this almost the same as rear discharge? Any pros and cons?
  3. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    Only con I can see is a lot of the time when a rear is requested its usually because theres an incline or whatever you want to call it, So if you backed down the bay with a belly unload you might leave a heel
    mustang190 and tscottme Thank this.
  4. Isxrookie
    82
    46
    Jan 24, 2011
    New Orleans, la
    thats what I’m thinking. I’ll be pulling non haz. Are those include load type specific or nah?
  5. tscottme
    tscottme Road Train Member
    Sometimes the customer wants to use their permanent hose which may not reach unload port in center of trailer.
  6. Isxrookie
    82
    46
    Jan 24, 2011
    New Orleans, la
    It has a pipe from that goes from the center to rear
  7. wis bang
    wis bang Road Train Member
    3,428
    4,066
    Jan 12, 2011
    Levittown, PA
    Matlack built some conicals 30/70 making the outlet closer to the pump.
    That would leave a heel in a pit where a rear valve, non-conical barrel would not; wouldn't matter on level ground.
    Most liquid customers have off-loaded enough product to know what is required at thir location.
    Pamela1990 Thanks this.
  8. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,719
    Nov 7, 2021
    B.C. Canada
    I deliver to a station where we back in, and its not level. Knowing that most fuel trucks are center unload, they built a concrete sloped ramp that we back onto. They were so kind that they even built about a 6" ledge at the back end of the concrete ramp, so we don't back too far.
    It would have been cheap, and easy to do.
    The trailer now level empties properly.
    All businesses should do similar if its unlevel where trucks unload.
    If it's a hose length issue, they can buy another piece to join on. If they can't afford 25' of hose, they are already doomed anyway.
    RockinChair Thanks this.
  9. Isxrookie
    82
    46
    Jan 24, 2011
    New Orleans, la
    I’m thinking of buying this trailer just don’t know i will have any problems like that. As far having to unload on a incline or some kind of situation like that.
  10. Pamela1990
    1,820
    10,719
    Nov 7, 2021
    B.C. Canada
    Most I see are central unload on the side, so should not be a problem. I've never pulled a rear discharge.
  11. Isxrookie
    82
    46
    Jan 24, 2011
    New Orleans, la
    How long have you been pulling tankers?
