Rear end help, 390 or 370 hauling cattle.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Vgarza32, Aug 9, 2018.
  1. Vgarza32
    Vgarza32 Bobtail Member
    19
    28
    Feb 27, 2018
    I have a 15 speed and I’m trying to decide between 390 and 370 rear ends. I haul cattle and I want to be able to run around 90 empty and when loaded not have to turn the truck up so much that it gets hot. I run tall rubber and have a 400 Cummins.
  3. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    Then you might want to run taller gears to lower your rpm. Taller as in like 3.22 or lower
  4. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    My 379 with a b model cat and a 14715 with 4 and 5 gear flipped backwards running thru 3.70 ratio on tall 24.5 rubber would run 75mph at about 1700 rpms 80 mph at 1800 that transmission overdrive gear was .079
  5. wore out
    wore out Numbered Classic
    15,845
    191,669
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I have a 90 model 379. 15 over 3.36 rears tall tires. 80 is 1600.
    snowman_w900 and Oxbow Thank this.
  6. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,542
    May 22, 2017
    This has me thinking hard?
    My old truck had lo pro 22, was 3.55 axles, with a 10 speed OD, and I ran 75mph or 80 mph at 1750ish. .73 overdrive. Would max out at 96mph 2100 rpm.
    Hauling reefer.
  7. wore out
    15,845
    191,669
    Jun 5, 2013
    There it is black and white at 1400 and 1750. It's a 15715 with .79 overdrive. Tall rubber and a B model CAT. 11R24.5 rubber. It's a triple digit truck loaded or empty. Nothing to wonder about
    snowman_w900, Tug Toy and Oldironfan Thank this.
  8. Oldironfan
    5,777
    5,542
    May 22, 2017
    Series 60 12.7 is the main difference.
    Tug Toy Thanks this.
  9. wore out
    15,845
    191,669
    Jun 5, 2013
    No it isn't
    RPM through a set of gears is the same regardless of engine. Tall tires and higher rears is the difference
  10. Oldironfan
    5,777
    5,542
    May 22, 2017
    Yes. I was a bit confused.
  11. AModelCat
    158,335
    I ran the calculator on my project W9 and it "should" just hit 100 mph at redline with 3.73's and the same transmission ratio and tire size you're running. Not that I'd ever think of trying that. 70 is plenty fast lol.
    wore out Thanks this.
