rear signal lights not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rudy5, Apr 14, 2014.
  1. Rudy5
    Rudy5 Light Load Member
    54
    Mar 17, 2013
    My 96 frieghtliner rear signal light went out. When I went to replace it, I found out that the new light had three wires (red, black, green), while the old harness and light had for wires (brown, blue, yellow, green). Does anyone know how I can install corresponding wires or the color codes? Going bonkers trying to figure it out using the "hit or miss" method.
  3. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    Brown is park/marker/clearance light
    blue is reverse
    yellow is left turn
    green is right turn
    red is normally stop, (or turn, as this powers the brighter filament in the bulb)
    black is also tail, normally
    green is odd ball in this combination.
    * I have never seen red, black, green combo before. Green is ground in house-hold wiring. I can't see green being used for the turn or stop light, as that is what the red is 99% of the time. You may have to fumble a bit to find the right combination. Hopefully someone else has seen this wiring before and knows exactly what it is .
  4. Rudy5
    54
    Mar 17, 2013
    Thanx heavy d. Now I have something to reference and not be do lost. Once again, thank you
