Rear sway on turns and curves on a Freightliner Century 2007
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Illustrious, Sep 6, 2015.
  1. Illustrious
    Illustrious Bobtail Member
    19
    9
    Jan 8, 2014
    Ok maybe someone has had a similar situation and can help me out.. Here is what's going on.. my tractor almost jackknifed on me in the rain one day... I had a very slight lean on the passenger side and later noticed my passenger steer leaf spring was slightly bent... So I had that replaced and after I started to notice that my drives were swaying in a fishtail sense on turns going up and down hills and curves they also fishtail when I drive bobtail this is very scary in the rain on my last load I only felt safe driving at 40 mph because it got really bad!! when I make turns with a trailer hooked up I fishtail especially turning to the left and my tractor rear swings and slides to the right almost into a jackknife as if I'm on an icy road and its a dry road... So I took it to a shop and they said my rear rear alignment could be off due to thrust angle... so I had a full alignment done at crenshaw in richmond, va and the problem persisted... then I took it to another shop and they were certain it was an alignment and that it was done on an old system.. so I had them do a full alignment and replaced the driver side leaf spring in case still the problem persisted... I also replaced my cab shocks and bads to make sure.. Any ideas? I feel like my rears are totally separate from the tractor.. what else could it be I have spent thousands of dollars trying to figure this out and I don't feel safe in my truck at this point for myself and others.. if this help my truck has 980K miles... only thing else I can think of is maybe the shocks are bad? however I don't see any signs of leakage and/or dried up leakage.. I bought the truck at 824K so I'm not sure if those are the original shocks.. please help thank you in advance ~Mel
    x1Heavy Thanks this.
  3. lots of character
    lots of character Road Train Member
    1,031
    1,814
    Aug 12, 2015
  4. AModelCat
    158,526
    If both those front springs were original, both should have been replaced since the old one is likely sagged over time. You didn't specify which suspension you have but if its the Airliner, they have a tendancy to pound out the spring eye bushings. Other things to check for are loose u-bolts, loose fastners, broken springs, broken spring center bolts and the condition of your torque arm bushings on top of the diff housings.
    BUMBACLADWAR, x1Heavy and Illustrious Thank this.
  5. Illustrious
    19
    9
    Jan 8, 2014
    Northernmechanic and lotsofcharacter thank you for your responses I will have the Torque arm bushings checked out.. and yes Northern both front springs were replaced last week.. again guys thanks!!
  6. xsetra
    xsetra Road Train Member
    5,109
    6,972
    Aug 21, 2011
    Could your fifth wheel plate be hanging up on your trailer. Either your plate is bent on the bottom of your trailer or your hitch plate is bent. Preventing or impeding your truck and trailer to articulate.
  7. Illustrious
    19
    9
    Jan 8, 2014
    my fifth wheel plate is fine. I have this issue as well bobtailing
  8. AModelCat
    158,526
    Here's another thought. Check your tire pressures. Tire shop put new tires on an old GMC Topkick service truck I ran but they filled the tires to 85 psi or whatever it said on the door jam rather than the 110 psi it read on the tire. That truck swayed and felt super loose in the ### end until I pumped them up.
  9. concdriver
    concdriver Bobtail Member
    48
    13
    May 19, 2012
    cambridge,on
    I have the same problem. Did you get this figured out yet?
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Stand over your drive tires from the side. Does not matter which side for all 4 of them (8 tires back there, 4 drive wheels) Lean over towards the frame from the outside top inwards until you look straight down past the wheel.
    If there is any problem at all wit the bearings you will notice that the brake pads are protruding from their assigned places inside the dru,.
    Im going to pause my postings today Some rest will assist greatly, and the spelling, grammar is the first to be lost when the symptoms make a assault against me.
  11. boneebone
    boneebone Road Train Member
    2,295
    2,366
    Mar 13, 2009
    If you have never changed your shocks out since you bought the truck, and have put over 156k miles on it and you don't know the history of when they were changed last.
    Your best bet is to change them as you are long overdue to replace them. You should've replaced them when you purchased the truck as truck shocks are inexpensive enough to replace, but are overlooked when diagnosing a problem
    Shocks don't have to leak to be bad, leaking shocks just means you've blown the oil seal. It doesn't mean they're good just because they're dry.
    You should replace the shocks every 100k miles or when installing new tires on your truck.
