Rear windows keep breaking
Discussion in 'Ask An Owner Operator' started by kameleon, Sep 5, 2019.
  1. kameleon
    kameleon Bobtail Member
    40
    19
    Jun 28, 2019
    I'm a brand new owner operator and I go off-road with my semi and little rocks get caught in my drive tires and get flung at my rear windows causing them to break. I need the cheapest solution:
    1. Fenders over the driver tires (expensive)
    2. Window guards (but I can't look behind me when I'm connecting to my trailer, even though I don't need to, but I'd like to.
    3. Plexiglass instead of glass, but I was told it might shatter in cold temperatures.
    What do you think?
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    You are already busting tempered glass windows back there. Plexi will break in it's due time in the cold. If thick enough it will take alot of rocks.
    Buy the wheel fenders. Nothing fancy, if you are in a land of rocks probably cheaper to bolt on replacement.
    And be careful digging your drives that violently into the rocks.
    88 Alpha and kameleon Thank this.
  4. D.Tibbitt
    148,557
    Maybe try some half fenders or quarters and see if it helps
    Tb0n3, FlaSwampRat and kameleon Thank this.
  5. kameleon
    40
    19
    Jun 28, 2019
    Thank you! Can I glue together two sheets of plexi to make it stronger? And the back windows are glued on, would the same type of adhesive work on the plexiglass?
  6. Capacity
    Capacity Road Train Member
    1,499
    3,118
    Jul 28, 2019
    Neenah Wi
    Are you pulling a belly dump , dont understand can't see trailer issue.
    Tug Toy Thanks this.
  7. AModelCat
    159,114
    2 minutes of searching. Under $400 for a pair:
  8. pushbroom
    pushbroom Road Train Member
    1,779
    7,313
    Sep 1, 2012
    Do it right, put a set of fenders on. Poly ones can be cheaper. Used ones also come up.
    Anything else is a waste of time and a temporary bandaid on the situation
  9. kameleon
    40
    19
    Jun 28, 2019
    I pull a chassis with a sand box on it out to the oil fields so I'm on gravel often.
    x1Heavy Thanks this.
  10. x1Heavy
    34,017
    42,135
    Mar 5, 2016
    Fenders then. How much have you sunk into windows. 400 should not be a issue one time.
    I usually threw shale rock off road in our ridges that have full of them. But the mixer had steel plate over the top of drives and on ends of them. That rock aint going anywhere. I might fall off the mountain but thats not anyones issue but my own.
    kameleon Thanks this.
  11. kameleon
    40
    19
    Jun 28, 2019
    I'm gonna get fenders then you guys are right. I appreciate it
