Rebuilding engines (volvo d12 engine)
Discussion in 'Ask An Owner Operator' started by Manfrmbklyn23, Nov 25, 2012.
  1. Manfrmbklyn23
    Manfrmbklyn23 Bobtail Member
    28
    Mar 2, 2012
    Brooklyn, NY
    I have a Volvo with almost 1 million miles (volvo d12 engine). Truck runs just fine no problems. My question, is there a bench mark in terms of mileage that an engine should be rebuilt? What is the general mile mark that an engine should be rebuilt? Thanks in advance.
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    My d12 has 1.2 million on it. I would say as long as oil samples come back good and has good oil psi and not using oil excessively keep running it.
    tommymonza Thanks this.
  4. Manfrmbklyn23
    28
    Mar 2, 2012
    Brooklyn, NY
  5. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    I agree with Jason. I have customers that rebuild just because they hit a certain mileage when you should be looking at how the engine is performing. Pull a sample. If brass is high, then look at rebuilding. If iron is high, do bearing roll in, especially if oil pressure is low. If aluminum is high, look at pistons. If all is high, full rebuild.
    Oh, hours are more important than miles. You can have a million miles with 1.2 million hours and be good. Truck next to you could be million miles and have 3 million hours and need rebuild. It really depends on how you run that engine. :)
    86scotty and SHC Thank this.
  6. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,012
    9,797
    Oct 18, 2010
    NW Indiana
    When to overhaul or not, that is the question. And no one has a definitive answer, if they do they are bull----ing you. That said, this is what I did:
    The truck in the little picture above had about a million miles on it, oil analysis was clean, I was the only owner driver, so I knew the history. Detroit Diesel said if you want a warranty on the overhaul it has to be done before a million miles, otherwise, no warranty. Soooo. In my previous life, I was an trained auto/truck mechanic. I decided to have a remanufactured engine installed right at the million mile mark. $25K out the door instead of $18 K, but new clutch, other reman/new accesories made it competitive. BEST THING I HAVE EVER DONE IN MY 35 YEARS TRUCKING, and most profitable.
    The biggest question is Do you want to do this sort of thing on your schedule in the shop of your choice, or chance a breakdown in god knows where, and are towed in to a strange shop, strange people and stranger prices.
  7. Manfrmbklyn23
    28
    Mar 2, 2012
    Brooklyn, NY
    Thanks for all the great feedback guys.
  8. mate1
    mate1 Bobtail Member
    Hi, I just rebuilt a volvo d12 engine and i can not start it without start spray, after it starts it works good. Does anyone have any ideas what could be the problem?
  9. Jerry_85
    Jerry_85 Bobtail Member
    Theres a 02 volvo d12 with over 1.2 million miles for $12000, is it too expensive,and with a lit of miles or is it ok?
  10. Bossdogg12
    Bossdogg12 Light Load Member
    67
    20
    Mar 10, 2013
    South Carolina
    Is it getting any fuel , check your fuel supply first
