Rebuilding pre model year 2000 Semi Trucks
Discussion in 'Experienced Truckers' Advice' started by Peterbuilt1013, Dec 30, 2018.
  1. Peterbuilt1013
    Peterbuilt1013 Light Load Member
    59
    28
    Dec 29, 2018
    Chicago
    Currently I'm working on a project rebuilding a 1996 Peterbuilt. Cat 3406E, 13 speed. I'm customizing the truck to maximize all the values that drivers need out on the road. I'm rebuilding the engine and transmission, brakes, air etc. Reliability will be as good as new. 575 HP to get you up those hills. ELD rule exempt plus no emissions drawbacks.
    *Satellite TV system
    *Cell phone signal booster
    *Paper logs (Exempt from ELD rule)
    *Tempurpedic bed
    *Customized surround sound.
    *Refrigerador, microwave and plenty storage.
    My question is, if you had to rent a semi from Penske. Would you rent a new truck with the computers, emission, ELD? Or would you rather rent an older truck that is customized for a driver out on the road. Plus the amenities listed above. I just want to know peoples opinion. Newer or customized older?
  3. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Rent? No question. New. Besides there's no way a Ryder or Penske could rent or lease an 1998 truck except to a handful of misguided individuals.
  4. HillbillyDeluxeTruck
    5,932
    30,316
    Mar 3, 2013
    San Antone
    I was on board until I didnt see stripper pole or disco ball listed.
    Im out. /shark tank
  5. AModelCat
    158,336
    I love old iron but unless the truck was stripped down to the axles and rebuilt 100% (new air lines, air valves, wiring, hoses, crossmembers, suspension parts etc) I'd rather have a new one.
  6. Peterbuilt1013
    59
    28
    Dec 29, 2018
    Chicago
    Everything rebuilt. Reliability is as good as new. I'm assuming most drivers would prefer older, plus exempt from the ELD rule would be a big bonus.
    Rideandrepair Thanks this.
  7. wore out
    wore out Numbered Classic
    15,845
    191,670
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The OP is bout to loose his ###.
  8. wore out
    15,845
    191,670
    Jun 5, 2013
    Nothing rebuilt is ever as good as new. When are people gonna realize non moving structural parts do wear over time. If not why do we counter bore blocks.
    Do not mistake me I run old iron. I know what it cost to tear one to the last crossmember bolt and start back. I drive my own truck pay its Bill's and treat it right. It's still a 1991 at the end of the day.
    Putting hired drivers or worse renting equipment like that out is a quick way to the poor house. They will beat it to death. Then your gonna have a salvage Peterbilt. Big #### deal about the paper log. Why advertise it? Those it appeals to already know the rule.
  9. STexan
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    What's it going to cost additional to run this truck (in fuel)? ie. what kind of MPG will it get at 80k running 65-70 mph coast to coast? You can factor in about 1.2 CPM DEF cost for the purposes of being fair in the cost comparison. My fleet-spec'd 2018 505hp Detroit last 2 quarters 48 state operation mostly above 77k has averaged 8.1 mpg and will probably out-pull your low-torque rebuild up any grade, pound for pound.
    Rideandrepair and 06driver Thank this.
  10. wore out
    15,845
    191,670
    Jun 5, 2013
    You didn't ask me but I can give a fair answer. 5.5 to 5.7 if he gets it right.
    I have seen 6 outta those trucks but were being driven by the owner
  11. AModelCat
    158,336
    @wore out nailed it.
    I'm doing an axle up restoration on a vintage truck for fun. New frame rails, cab structure requires repairs, engine/powertrain overhaul, all new wiring, hoses. etc. I've gotten 5 figures into it not counting a couple hundred hours of my time and I haven't even started buying engine parts or tearing the cab apart for frame repairs. Basically just have a rolling frame, a rebuilt 15 speed and a stripped down engine.
    Point is it takes a lot of money to rebuild a truck to new quality. If its just going to be a rental, its pretty much a given that its going to get the piss driven out of it.
    Reason for edit: Added more to post
