Recommended shocks for a Peterbilt 387
Discussion in 'Peterbilt Forum' started by mad103, Jun 24, 2010.
  1. mad103
    mad103 Bobtail Member
    30
    What shocks would you recommend for a 2007 Peterbilt 387 front axle?
    Advice please
  3. dmg1029
    dmg1029 Light Load Member
    182
    55
    Jun 6, 2009
    Coeur d Alene, ID
    My first truck was a Pete 387. I spent lots of $$ and time on the suspension. I used Gabriel shocks. One issue you WILL always have is the 'popping' in the front end. The rear shackles on the front springs 'twist' and cause this. You can 'shim' them every 50K or so. Pain in the arse!!! I had several other issues that I would be glad to discuss with you if you want.
    Good luck
    PS, what engine, transmission?
