Red Ant light of death.
Discussion in 'CB Radio Forum' started by Bwakers, Apr 13, 2021.
  1. Bwakers
    Bwakers Bobtail Member
    4
    Apr 13, 2021
    Ok fellas, here’s one to confuse you. My radio has been working fine until yesterday. Then I get the Red light of Death on ant when I key up. Read the forums and everyone says the same thing Ground issues. This is a new Mack truck (3 months) and was working great with factory setup. I stopped at a CB shop to have it checked. They put on a single Wilson type antenna and bracket and ran new coax to the radio. I can get out and receive now, but still have the red light. Confused
  3. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    Mine always lights red when I key up??
    Mine is a cobra 29
    NavigatorWife Thanks this.
  4. Bwakers
    4
    Apr 13, 2021
    Mine is a 29 LTD Classic, the Rx/Tx light turns red when transmitting, but the Ant light shouldn’t come on unless there’s an issue. So I have been told.
  5. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Sounds like you've theoretically removed the antenna system as a possible problem. It would be interesting to see if a spare radio you have exhibits the same behavior
    NavigatorWife and Bwakers Thank this.
  6. kemosabi49
    10,913
    47,386
    Jan 13, 2013
    SW Arkansas
    My 29 ant light would come on if the SWRs were way out of whack.
  7. Hulld
    Hulld Road Train Member
    2,884
    6,567
    Oct 19, 2015
    Upstate NY
    I believe the light is supposed to be lit up when transmitting.
    When the light starts flashing when transmitting is when you have a problem.
  8. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    If you haven't yet, get a $25 SWR meter with a 2' jumper cable between the antenna and the radio. See what it says. If it shows 1.5 or less, put a piece of tape over the red light and drive on.
    rachi and NavigatorWife Thank this.
  9. OldeSkool
    OldeSkool Road Train Member
    1,903
    5,862
    Jul 17, 2018
    New Hampshire
    My Cobra 29 ant light always comes on when I key up too. I don’t think they are supposed to, because it didn’t in my old truck with a different radio, (same kind though,) but I can’t figure it out and finally just gave up. It talks and receives fairly well.
  10. Bwakers
    4
    Apr 13, 2021
    I have had issues with cobra radios before with solder joints going bad
