Red knob not popping out.
Discussion in 'Volvo Forum' started by Snailexpress, Mar 28, 2018.
  1. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    I know if trailer emergency line disconnect the red knob should pop out simultaneously and air should stop leaking from tractor. Mine doesn't popping out and air still leaking. Which valve to replace?
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Most tractor protection valves are all one unit. Can't replace separate. Usually easy to do yourself, if inclined to do so.
    Snailexpress Thanks this.
  4. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Oh i might add. If you pull off service gladhand from trailer. The red button, knob whatever should pop out at around 60psi, when your air gets down to that point. Not pop out instantly.
  5. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    No problem with wrenching. I don't know which valve to replace. One is called tractor protection valve is on the rear of the cab. Red dash knob valve? Have read a lot of manuals but in all manuals says if it working this way everything is OK. No any words what if test is not pass.
  6. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    It should pop out instantly or OOS. Unfortunately. Knob is popping out when pressure drops down.
  7. Dave_in_AZ
    372,498
    You sure about that. I've pulled that line off multiple times over the years, on different tractors, and it flows air until 60.
    I mean if it falls off when your going down the highway, the spring brakes are gonna come on instantly on the trailer.
    I've had the service brake fall off with a loaded trailer, and it was a B to stop.
    Blackshack46, Hulld and AModelCat Thank this.
  8. AModelCat
    154,929
    The red knob WILL NOT pop out instantly if you break the red gladhand. The trailer brakes need to apply instantly but the tractor air supply will need to drop down to around 60ish before it pops.
    Blackshack46, Hulld and Dave_in_AZ Thank this.
  9. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Think proper name is tractor protection valve. Yellow and red push knobs on dash. If you undo whatever holds them secure, and pull them out..they are one unit hooked to air lines. Proper way to check is with engine off, tractor brakes set (yellow knob pulled out). Leave red knob in and pull off service line to trailer (red marked gladhand). Air rushes out hop up and watch air psi. When psi gets to around 60psi it should pop out.
    BluePete05 Thanks this.
  10. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Correct
  11. Bean Jr.
    Bean Jr. Road Train Member
    5,480
    9,717
    Mar 30, 2014
    Blue is service, red is emergency or supply.
    The two valves come together, so you replace them both. I just bought one to put on, but I have heard they are not easy to replace. The hoses that are attached are not that long, so you have to swing wrenches in the dashboard.
