Redneck repairs
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Chasingthesky, Jan 12, 2017.
  1. Chasingthesky
    Chasingthesky Heavy Load Member
    936
    1,569
    Apr 30, 2010
    Denver, CO
    What's the worst/funniest you've seen? I stopped to look at some trucks in Selmer, TN today and found this first rate exhaust work. Watch out for bumps
  3. bzinger
    bzinger Road Train Member
    16,607
    65,869
    Dec 10, 2014
    omaha , ne
    Yanked the ink cartridge out of a ball point pen once and used the shell to sleeve a trailer tandem hose the had dragged .
  4. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    The bolts fell out that held my air wiper motor in place on my old CO4070A,back in the day in a hard rain,no wipers.Found a little block of wood along the highway,jammed the motor back in place,wipers worked great.Forgot about it,ran that way for months,worked fine.
    snowman_w900, Oxbow, MJ1657 and 4 others Thank this.
  5. Chasingthesky
    936
    1,569
    Apr 30, 2010
    Denver, CO
    Reminds me of the old dodge pickup I used to drive. The plastics bushings that hold all the windshield wiper linkage together went out one by one, usually in the middle of a downpour. Had the whole thing held together with wire by the end of it but it still worked fine.
    ShooterK2 Thanks this.
  6. Animosus
    Animosus Heavy Load Member
    711
    2,800
    Dec 7, 2015
    SE Wyoming
    I think the most ghetto thing I've seen is a oil pan leak "sealed" with a t-shirt and 10 tubes of silicone. Just fix the #### oil pan.
    bzinger, ShooterK2 and Chasingthesky Thank this.
  7. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    My stinkin' old AG200 suspension broke and let the rear axle swing back on one side. Used a chain and boomer to get it back in place so I could unload and get back to the shop. Not once but twice.
    Upgraded to AG400 and cured all those problems.
    snowman_w900, MJ1657 and Chasingthesky Thank this.
  8. Duurtipoker
    Duurtipoker Medium Load Member
    376
    613
    Nov 3, 2016
    Hagerstown, MD
    This wasn't on a truck but....
    I had an older Buick Century with a "newer" electric cooling fan. For some reason it stopped running. Some relay somewhere wouldn't kick it in so I was overheating. I was young and broke so a garage was out of the question. So I found a fuse in the box that was live all the time, no key needed. I ran wire to a toggle switch I mounted by cutting a hole in my dash and bolting it in, than to the fan. Worked great as long as I remembered to hit that toggle when I started the car and when I parked the car.
    Ed
  9. AModelCat
    156,225
    I have a photo album full of pics of redneck fixes on my project W9.
    -Welded cast iron suspension hanger on the rubber block suspension.
    -Piece of rebar welded to the rear cab mount bracket to reinforce a cracked area.
    -Foil from a cigarette package to ground the back light of the pyro.
    -Piece of tin siliconed over a hole in the firewall where the A/C evaporator was supposed to go.
    -Wires tied up with many feet of electrical tape instead of proper clamps and zip ties.
    -Gob weld on a cracked aluminum crossmember.
    -Old frame rails had a couple holes blown through them with a torch to mount accessories instead of drilling.
    -Tubes of silicone to seal roof lights, horns, etc.
    These are just off the top of my head. I'm sure if I thought about it, I could add many more to the list.
    BoxCarKidd, Chasingthesky and DougA Thank this.
  10. DougA
    1,429
    8,892
    Dec 16, 2013
    No one ever bought new fuses in the old days.Most everyone smoked,and a piece of cigarette pack foil was wrapped around the fuse,then snapped back in place.
    Grubby, mtoo, Oxbow and 1 other person Thank this.
  11. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    My first car the exhaust hanger broke, the only thing I had with me at the time was a large bag of 1/2" wide leather strips. It got me home where I could get the baling wire. Vehicle never leaves the driveway without baling wire now.
    Chasingthesky Thanks this.
