Reefer breakdown,what to expect when I will be delivering on monday?
Discussion in 'Ask An Owner Operator' started by forestcat, Oct 21, 2012.
  1. forestcat
    forestcat Bobtail Member
    18
    Feb 21, 2009
    New York, NY
    Hi, I was hauling cabbage in a 53 feet reefer. I picked up cabbage on Thursday and will be delivering Monday morning. The set temperature was 34 degrees on a continuous mode. They also put a temp recorder. I had a reefer breakdown and it took dealer 9 hours to complete repairs. Meanwhile temp inside the box rose to 57 degrees. What to expect when I will be delivering cabbage on Monday? Will it be rejected?
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    better be calling the broker/Dispatcher ASAP if you haven't already.
    Don't plan on dealing with this alone. Call them NOW and get them into the loop so they can deal with the consignee. That's their job. Help you deal with major issues like this.
  4. ShortBusKid
    ShortBusKid Heavy Load Member
    955
    1,269
    Dec 5, 2010
    Vegas
    Cabbage is pretty hardy stuff. You're probably ok. I would follow MNdriver's advice and tell your boss or the broker or both. I've hauled a cabbage/onion mixed load at 45 with no issues so I doubt a few hours at 50+ is going to cause an issue but CYA just in case.
  5. flc120
    flc120 Heavy Load Member
    916
    122
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    temp recorder is what screws you as thats what will give them a timeline to what happeneded thus leaving it impossible for you not to tell them.
  6. forestcat
    18
    Feb 21, 2009
    New York, NY
    Thank you guys for helping me out with this, I run under my authority and the broker will be back in office on Monday and I will be delivering the load. So, yes, they will find out. What if I just take the recorder and throw it away? Is it an option?
  7. MNdriver
    7,985
    4,372
    Feb 24, 2012
    Only if you want to guarantee your load be rejected. You need to call your broker today. This is something you should have done when the reefer broke down in the first place.
  8. forestcat
    18
    Feb 21, 2009
    New York, NY
    ok, so what I learned that cabbage is not lettuce and strawberries and I might be ok, I hope so. They do not work today, anyway.
  9. MNdriver
    7,985
    4,372
    Feb 24, 2012
    they should have an after hours number you can call. Rare that they would not.
    Otherwise, contact the broker BEFORE you go into the consignee on Monday and give them a heads up. They can decide if they should call the consignee before you arrive and have a plan of action before you even hit them with the issue.
  10. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    probably gonna be priced down if they dont reject it be prepared to do alot of sittin around and stressful day ahead of u. I just had a friend his reefer broke down, load of bananas temp went above 65 n it got rejected 8grand was the loss
  11. forestcat
    18
    Feb 21, 2009
    New York, NY
    feel sorry for your friend, yes it part of business with reefers, just trying to find a better solution :)
