Reefer Drivers - Clipping seals off at receivers, what to use?
Discussion in 'Experienced Truckers' Advice' started by FearTheCorn, Jun 7, 2025.
  1. FearTheCorn
    FearTheCorn Medium Load Member
    648
    2,507
    Jan 6, 2019
    Omaha
    I am done farting around with the seals meat plants use. Those things can be used on an aircraft carrier anchor chain. I want to snip quick and easy. Please advise.
    Canadianhauler21 Thanks this.
  3. Rugerfan
    Rugerfan Road Train Member
    7,326
    36,147
    May 3, 2011
    Redding,CA
  4. rollin coal
    rollin coal Road Train Member
    13,267
    26,719
    Mar 29, 2008
    TN
    You talking about cable seals? I tried a few knippers over the years but the best thing I found was a cordless Dewalt angle grinder with a cutoff wheel.
  5. FearTheCorn
    648
    2,507
    Jan 6, 2019
    Omaha
    I have bolt cutters. You have to twist and turn and all that crap. What I am looking for is a quick snip. I had a seal that could have strangled Godzilla once when I did a delivery in Texas. The receiver chick came out with some clippers and snapped it off clean as can be. She disappeared before I could ask her where she got them.
  6. wulfman75
    wulfman75 Road Train Member
    2,095
    2,540
    Jul 15, 2010
    Athens, GA
  7. FearTheCorn
    648
    2,507
    Jan 6, 2019
    Omaha
    So those do the deed? I am going to hit up Ace Hardware or Menards. I have a broken seal with me to give it a try.
  8. rollin coal
    13,267
    26,719
    Mar 29, 2008
    TN
    Some are better than others. Never found a pair that was worth a crap. Bolt cutters will cut the center lead piece that the cables go into just fine. I still preferred the angle grinder.
  9. 062
    062 Road Train Member
    6,201
    33,404
    Oct 20, 2013
    Just make sure it’s rated for steel/wire rope. Some are for copper and won’t last long.
  10. Professor No-Name
    Professor No-Name Road Train Member
    3,958
    7,638
    Nov 26, 2016
    These are what I've seen at some places I've been to that they use to snip braided cable seals. They work really well. I've not been able to find any at any stores. If you can find a pair please post as to where at.
  11. ducnut
    ducnut Road Train Member
    2,570
    7,739
    Dec 31, 2010
    SPI
    I have these:
    https://a.co/d/0M1V4re
    I’ve seen these powered cutters used at a gate station of a high-volume food distributor. They go through those bolt seals like nothing is there. Very expensive, though.
    https://www.greenlee.com/us/en/battery-cutters
