Reefer fuel in a P/U ????
Discussion in 'Experienced Truckers' Advice' started by northstarfire0693, Mar 14, 2011.
  1. northstarfire0693
    northstarfire0693 Heavy Load Member
    862
    594
    Jul 1, 2006
    NC
    I was down in the lower 48 last month and we stopped in at the local Pilot in San Antonio. We went in the truck lanes to fuel the truck and next to us was a 3/4 ton P//U with a aux tank in the rear bed. The driver fueled up his truck then switched off the pump and fueled up the aux tank. I made the little remark to him and said going for the cheep stuff.... he said yep.
    I did not think that was legal to do ? but then again with the high cost of fuel ????? man got to make a living.
  3. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    did he put the reefer fuel in the truck or in the jockey tank ?
    he could be using it on his farm which is perfectely legal--but if he is burning it in the truck--i wouldnt want to be caught with it---chances are he wouldnt be caught--but you never know
  4. northstarfire0693
    862
    594
    Jul 1, 2006
    NC
    jockey tank. I just did not think you could just drive up stick your credit card in and pump reefer, but you could be correct he could be using it on a farm or something like that
  5. Rockin&Rollin
    Rockin&Rollin Heavy Load Member
    798
    6,325
    Mar 6, 2011
    Orlando Florida
    Nothing wrong with putting off road fuel in an auxiliary tank. If one uses it on road it can be very costly like a $10,000 fine depending on the state. On top of that the IRS will come after you for cheating as well!
    I've seen DOT sticking regular ol' pickup truck tanks at farm/logging shows and auctions in WI. I heard that if a driver has a company truck and gets caught both the driver and the company get a huge fine but not sure if that part is true. It is true it's not worth getting caught using it on road either way though!
    Lots of pumps at gas stations that do not serve heavy trucks sell it here
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Alot of them guys have a backhoe or other offroad equipment and it's perfectly legal.
  7. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,693
    16,281
    Jan 18, 2011
    From what i see here--he did fuel the truck also--this practice is not as uncommon as you may think--although not as common in larger t/s--almost all my farm neighbors do the same thing--while it is illegal to run off road fuel(untaxed--fuel is the same!!)on road--really who is gonna check--especially off the beaten path.
    Besides would be kinda tough to check fuel(although not impossible)in a P/U--not like your gonna easily dip the tanks--
    but my biggest question to y'all out here is? How many times since they have been dying fuel-(if you have been out here that long)-have you been checked?
    It has happened to me a grand total of TWICE in the entire time I have been out here and they were 12 years apart--and hasn't happened in the last 6
    just my$.02
  8. Inland-Pilot
    Inland-Pilot Light Load Member
    229
    135
    Jun 23, 2010
    Jackson, Ms
    at Pilot, u can't get tax-exempt farm fuel in the truck lanes... when he switched the pump off and then back on it switched to reefer fuel status which is the exact same fuel he pumped into his truck but doesn't include the highway use taxes... reefer fuel isn't taxed like highway fuel, that's why you switch the pump off then back on, to change the taxes... it's the same fuel, it's not red farm fuel as your thinking, and if he's filling an aux tank then it's legal until he pumps it into his truck tank.
  9. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    The red dye is mixed into the diesel at the fuel rack (the tank farm where the fuel trucks fill their delivery tanks)...and is exclusively for farm/ag use. The red fuel is not delivered to the truck stops but delivered directly to the farm/ag business...there wold be no way to dye fuel at a truck stop.
  10. Flying Dutchman
    Flying Dutchman Road Train Member
    1,274
    522
    Nov 2, 2009
    Northern California
    I know of a guy that runs an auxiliary diesel tank in his 1 ton diesel pickup, full of red diesel. His pickup tank is full of highway diesel. It has been for a long, long time. He has his auxiliary tank plumbed into his pickup and burns the red diesel all day long. But for fuel checks, which are pretty common in CA, he passes with flying colors (or no color, to be precise!) when they dip his standard fuel tank.
    outerspacehillbilly Thanks this.
  11. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    Just to clarify, red dyed fuel is the good old high sulphur fuel as far as i know...
