Reefer: Recommend fixed spread or sliding closed tandems?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AdamT2k, May 11, 2010.
  1. AdamT2k
    AdamT2k Light Load Member
    120
    43
    Feb 6, 2009
    Minneapolis, MN
    Okay, if the title didn't make sense, here goes... I'm looking for opinions from drivers that pull reefers with fixed spread axles. Have you ever run into a load that you cannot get to scale? Are you able to load 40k into the first 40 feet of the trailer and get it to scale legal? If you had your choice...would you pull a spread or a closed tandem? And why? Thanks for all the advice in advance. (Mods I hope I placed this thread in the right category!)
  3. trips74
    trips74 Medium Load Member
    367
    217
    Nov 7, 2007
    chicagoland, il
    Ive always pulled closed tandems and can easily load 44k in those specs. We run cali produce loads with 53' closed all the time. if you are over weight take it back and have the shipper correct it. The spread looks like it would help but to me seems like an extra step. U should be fine with a closed axle.
  4. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    I have never met anyone with a spread that would ever go back to a slider.
    AdamT2k Thanks this.
  5. BIG RIGGER
    BIG RIGGER Road Train Member
    1,071
    414
    Feb 25, 2010
    Fargo,ND.
    There nothing easier to axle out or manuver than a spread with a rear axle dump valve no matter what the application.
  6. Gears
    Gears Trucker Forum STAFF - Gone, But Not Forgotten.
    4,511
    3,184
    Aug 20, 2009
    I would.....NOT!!!!:biggrin_25522:
    I don't and won't pull heavy loads but know I can with this baby. I don't have axle dump valves to the cab with this trailer (yet) and sometimes backing requires an extra pull-up, but so what!:biggrin_25526:
    I've pulled both tandem and spread, even owned a '53 sliding spread for short while. The ride much better when pulling a spread. Even when I get pulled into a scale, it seems the green light is on all the time, like the scale master is thinking "Why even bother weighing this guy?"
    When pulling a sliding tandem, I never enjoyed weighing at truckstops and sliding the tandems back and forth. To be honest, I've NEVER weighed my truck with the spread.
    The Challenger and AdamT2k Thank this.
  7. AdamT2k
    120
    43
    Feb 6, 2009
    Minneapolis, MN
    Gears, do you find that your trailer chews up tires quicker than a closed tandem? And when you say you don't pull heavy loads, what's your definition of heavy? Right now I pull a 53' reefer with sliding tandems and am considering all the pros and cons of a spread. Is it true the ride quality of a spread is that much better too? Thanks guys for your input.
  8. Gears
    4,511
    3,184
    Aug 20, 2009
    Sure, your front axle tires will wear quicker if you do jack-knife backing or just plain do a lot of city driving (turns are the culprit).
    I pull loads of 40,000 or less although I could easily go heavier. Other spread owners here will attest to that. There is a noticeable ride improvement when compared to a tandem.
  9. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    True a spread will wear out tires faster but in most applications it's trivial. Dump valves can help save them some but driving habits can help the most. Think of it this way, a trip from say Michigan to Florida. How many turns would make on that run where a spread would make any measurable difference in wear? In my experience the majority of people who say their not worth it or claim higher costs have never owned or even pulled a spread axle trailer.
  10. staceybetz
    staceybetz Bobtail Member
    5
    May 26, 2010
    Bazine, KS
    I pulled a spread axle step-deck for many years. was always grossing 80,000. Tire wear is not a big factor if you drive it right. No tight corners...... make them big! Also pulled a spread axle reefer (until another driver decided to take his hood off with it). Once you drive a spread and get used to it, you will never want to drive anything else. yes, without a dump they do turn wider..... small price to pay for not having to worry about axleing out and the best part..... NO MORE SLIDING YOUR AXLES!
  11. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    Loading a spread axle reefer is almost idiotproof. If you are loading say 22 skids at 2000 pounds each you cannot do it wrong. Run 'em all straight in an go. I dont know how many times I get funny looks from forklift operators when I say to not single any skids. I run 22 straight in and I'm still light on my drives. The front trl axle really takes alot of the weight. Once you go spread you'lll never go back. Quick dumps are your friend although not *ahem* lega...........
    AdamT2k and The Challenger Thank this.
