Reffer Madness, alternator not charging the battery.
Discussion in 'Experienced Truckers' Advice' started by scott180, Nov 16, 2021.
  1. scott180
    scott180 Road Train Member
    1,217
    4,222
    Dec 10, 2012
    Tooele, UT
    Got an alternator not charging alarm on my reffer. The belt is good so probably a alternator.
    Hooked jumper cables from truck to reffer battery. Cleared the alarm but within a few minutes the alarm was back on and the light went to orange again.
    Anyone with any experience with this?
    I have a 5am drop off (10 hours from now) and then a non refrigerated load home.
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    You should carry a piece of 10 gauge wire with clamps on both ends, long enough to go between your truck batteries positive post and the positive post on the starter of the reefer, just for this kind of emergency.
    If you're sitting until tomorrow morning, just leave the jumper cables on it.
    scott180 Thanks this.
  4. 062
    062 Road Train Member
    6,290
    33,834
    Oct 20, 2013
    Check your positive and ground connections at the starter and block.
  5. Trucker61016
    Trucker61016 Road Train Member
    1,435
    4,258
    Sep 18, 2017
    Linville, Va
  6. buzzarddriver
    3,732
    11,074
    Feb 1, 2011
    Dallas, TX
    And put it on continuous run if not already set that way.
  7. DRTDEVL
    DRTDEVL Road Train Member
    1,706
    3,429
    Jan 27, 2013
    Austin, MN
    Just put it on continuous and make your delivery. Repair the reefer after you get through with your current dispatches.
