Regear cost?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 379exhd, Oct 15, 2013.
  1. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    Does anybody have a rough idea what it costs to regear both rears? And is there a huge cost difference between Rockwell and Eaton rears? I called a couple shops and was quoted between 4500-6500 to regear both rears with 3.36s does that sound about right? I was figuring maybe $3500 on the high side of it maybe I'm crazy and wanting something for nothing but $4500 seems high and $6500 is flat out insane. Truck has Rockwell rears under it could that be where my added cost is?
  3. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    Rockwell rears are the cheaper more common drive axles. If its 40's it would be $2500 for both reman rears. The rest is pulling and then installing.
    Ezrider_48501 and 379exhd Thank this.
  4. 7.3 cowboy
    7.3 cowboy Light Load Member
    210
    59
    Mar 4, 2013
    THe truck I just bought has rebuilt rears, paperwork he gave me said the one reman gear set was 2000$ and the other 2300$ for the parts and that was switching from 3.90s to 3.55s. Why you want to regear?
  5. See Are125
    See Are125 Light Load Member
    78
    40
    May 23, 2013
  6. Cetane+
    1,304
    882
    Sep 29, 2013
    Albany, NY
    He has height issues. Doesnt want to go taller.
  7. 7.3 cowboy
    210
    59
    Mar 4, 2013
    He wanting to drop to 3.36 and lo pro 22.5?
  8. Lewis9698
    Lewis9698 Bobtail Member
    21
    Dec 2, 2013
    Orlando,Fl
    The difference between 3.42 and 3.36 isn't enough for any money get on eaton fuller website go to toolbox and check it I think you will be disappointed
  9. black ultra
    black ultra Light Load Member
    62
    13
    Feb 16, 2012
    conroe tx
    There probably isn't a 5 mph difference between the two!! However you can buy a ring and pinion set reasonable! The expensive part of working on rearends is the bearing kits,axle gears & spider gears!!
  10. black ultra
    62
    13
    Feb 16, 2012
    conroe tx
    You may also check salvage yards for pullouts! In Houston Texas all the salvage yards have plenty high geared stuff! I would figure the rest of the states have just as many! I put 2:93 ratio in my 99 Pete!!!
  11. truckman29801
    truckman29801 Medium Load Member
    469
    109
    Mar 10, 2013
    SC
    That sounds about right, The previous owner of my FLD dumped 4300 for both rears.
