Regen AGAIN :-(
Discussion in 'Ask An Owner Operator' started by mover man, Aug 2, 2018.
  1. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    How often does your truck require a parked regen? I just did one a week or so ago, maybe 2000 miles at most. I NO idling probably has something to do with it. But my buddy with same exact truck. Hasn't had to do one in months. I think maybe it' time to get my filter baked or replaced. Of course it' always required when I'm on tight time schedule Grrrrr
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    you cannot compare trucks, but maybe driving/idling habits...
    maybe he idles LESS than you do.??
    maybe his filter had been baked long ago.>???
    you could have 300 trucks, and 400 drivers, no 2 will be exact in the truck nor drivers.....
    mover man Thanks this.
  4. mover man
    1,698
    1,801
    Feb 21, 2010
    Yes of course you cant make an exact comparison. But there always is an average. That's what I'm trying to figure out.
  5. bryan21384
    bryan21384 Road Train Member
    15,700
    34,193
    Sep 18, 2009
    Memphis, TN
    If you Regen more frequently, and it won't stay in it longer than 15 min, than you need to bake the dpf. It'll repeatedly require regens. To reduce regens, don't idle as much, and use your cruise control instead of driving with your feet to the pedal.
  6. AModelCat
    164,540
    Regen is done to clean the soot out of the DPF. So basically it could be 2 things. Either your truck is producing more soot, or the DPF differential pressure sensors are reading incorrectly, telling the ECM the DPF needs a regen.
    Building off my first point: It is definitely possible its time for a DPF cleaning. Over time ash builds up and reduces the DPF's soot capacity. Less capacity = more frequent regens.
  7. 86scotty
    86scotty Road Train Member
    4,699
    12,897
    Aug 27, 2017
    Appalachia
    What truck? Does yours have a soot gauge? My 2015 Volvo does. I'm only 20k into ownership but it hasn't done one yet (in a month).
  8. supersnackbar
    20,081
    52,463
    Aug 19, 2007
    Your Town, USA
    After 9 months at this company, and I am in a Mack, mine has requested 1, and that was when I was having injector issues. And over the last few months, my idle percentage is in the 70% range. Regens, if everything is working right, should be done while moving (passive regen). If you're doing a parked that often, something is amiss.
  9. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Is regen switch set on off/auto/manual mode? If so, make sure its set in the middle position-auto regen, while youre driving it should be doing regen. As long as youre rolling 50mph or higher and have a load it should do automatic regen.
  10. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    If it’s a 2010 or later you shouldn’t be doing parked regens unless something is wrong with it or you’re in a sever service application.
  11. Brandt
    Brandt Road Train Member
    4,624
    6,358
    Sep 17, 2012
    Manual parked regen is going away DPF may need cleaning. My 2017 truck has 231,580 miles and never needed a Manual parked regen. When I idle the truck, it does automatic parked regen. If needed. It only takes 20 minutes at 1250 RPM. It only happen after 6 hours of idle time. The computers do all the work now. Going down the road it does everything automatic also.
    I have the Optimized Idle System. The computers start the engine for heat or a/c and battery charging and engine olo temperature. Detroit S60 had this back in the 90. It back and now the computers also do automatic parked regen if needed
