regen failed due to low temp dtc 3711, dd15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RTR tech, Mar 18, 2018.
  1. RTR tech
    RTR tech Bobtail Member
    8
    Mar 18, 2018
    Tractor was towed in with engine warnings on, and in shutdown mode.Active faults for soot level high, and failed regen. due to temp. Inlet DOC temp only at 425, wont go high enough to start dosing fuel. Intake throttle valve is working. Will continue on diag tomorrow. Any thoughts? Thanks.
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Come on guys!!!! For the millionth time year/make/model/engine.
    Goodysnap and daf105paccar Thank this.
  4. Antinomian
    Antinomian Road Train Member
    2,089
    3,262
    Feb 17, 2013
    Is the EGR valve working?
  5. Freddy57
    Freddy57 Road Train Member
    1,731
    8,246
    Nov 29, 2013
    Mount Vernon, MO
    Sounds like EGR stuck open.
  6. RTR tech
    8
    Mar 18, 2018
    Sorry about that. Sent from home and not fully thinking. Tractor is 2013 Freightliner Cascadia with Detroit DD15. A little over 500k miles. Not a lot of history as far as aftertreatment work done.
  7. bryan21384
    bryan21384 Road Train Member
    14,581
    31,256
    Sep 18, 2009
    Memphis, TN
    That dpf may be clogged. It may may need cleaning. When the soot levels get too high, the truck will either have short regens or none at all. They'll have to take it off and bake the filter or how ever they clean it. You'll be down for at least 12 hrs.
  8. RTR tech
    8
    Mar 18, 2018
    Found the problem Reached a step in diag instructions to inspect valve adjustment. The engine brake solenoid on front section had come loose and was popped up out of position. After replacing O-rings, tractor did complete regen with good temps. Tractor had some work under valve cover a couple of months ago. Looks like this screw didn't get tightened enough. Thanks to all for your input.
    QUALITYTRUCK and Jazz1 Thank this.
  9. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Good job finding something simple. Had similar issue with my own vehicle recently. Bolt on EGR tube had fallen out and making the engine somewhat erratic
  10. mccoy12
    mccoy12 Bobtail Member
    i have a 2015 cascadia dd15. has a 3719 fault.. both dpf filters have been replaced. dozer injector has been replaced. exhaust temps are only reaching 460 degrees.which isnt high enough to starting adding fuel on the downstream. trottle valve is working properly. egr valve is not stuck. any ideas?
  11. Antinomian
    2,089
    3,262
    Feb 17, 2013
    Here's a link to the service bulletin: CPC4 SPN 3719/FMI 0, 16 - GHG1 .
    You may need a new CPC4.
    Are there no other codes?
