Regen failure need advise
Discussion in 'Kenworth Forum' started by Platinum Sky, Jan 1, 2015.
  1. Platinum Sky
    Platinum Sky Bobtail Member
    31
    6
    Oct 27, 2014
    Hi everybody and happy new year,
    this is is my first experience with KW2012
    this truck has over 700k miles
    after driving this truck for 500miles......all sort of problems appeared
    yellow chk engine
    red stop engine light
    I took the truck to desiel Michanic and we found out that the DPF has crack and smoke comes out from there
    the Michanic welded that piece of DPF
    and when he actually started working on the truck all chk engine lights disappeared! But he couldn't do the regen!!!!!
    I started driving and. After 200miles the yellow&red engine light came on and the regen sign.
    now when I bush the regen button on it gives me (regen inhibited)
    thank you you for your advices
    i can't find any michanics now, and TA said they only can do diagnose
  3. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    You are O/O I guess right?.
    Happy New Year is only good words I can say to you, sorry.
    You have a serious problem with regeneration system. TA mechanics can't help you. They don't have experience and qualification to troubleshoot problems, They can only put new parts on.Your wallet will be drained and truck never fixed. You need mechanic familiar with Insite to run forced regeneration and troubleshoot entire system.
    Where are you by the chance I can help ?
  4. Cat sdp
    Cat sdp . .
    20,886
    72,325
    Apr 8, 2012
    Orion's Belt
    A dealer is your only hope...... And I don't know what you "welded" but it may void any warrantee you have....
    Is it a isx or a mx.....?
  5. Oldman49
    Oldman49 Medium Load Member
    353
    299
    Jul 20, 2014
    Had that issue with a RED colored motor. Dealer found a bad sensor located in the filter somewhere,,,was an easy fix but he used his computer to locate and verify.
  6. snowwy
    snowwy Road Train Member
    20,529
    13,267
    Jul 6, 2009
    dpf only comes with 250k mile, can be extended to 500k mile for a price. his truck has 700 so he's outta warranty anyways.
    the problem could be any number of things, from a bad dpf to a sensor. and only the dealer can help.
    mine was the dpf, cost was $4500 to replace.
  7. tirednaz
    tirednaz Heavy Load Member
    838
    430
    Oct 4, 2011
    Arizona
    I think with the miles your ready for a new DPF. I got 600,000 out of mine then needed to replace it. $1100 for the part and $115 for the dealer to reset the code after it was installed.
  8. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    Also sounds like you have recourse against seller. It appears you have driven the truck less than a thousand miles so I'm thinking yes......
    Be aware though...any second line seller like Arrow is not going to pay dealer prices....he will want to use his preferred shop.
    I'm curious to know what happens here.......be sure to check back.
  9. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    Ouch, Had mine replaced at cummins for 1800$ and that was a OEM dpf filter not a 3rd party.
  10. snowwy
    20,529
    13,267
    Jul 6, 2009
    how did you get yours that cheap?
    vegas tried to sell me a dpf clean. apparently FL's have a mileage counter that trips the engine light. to have it cleaned. vegas doesn't have a machine. they send dpf's out. charge is $2400. salt lake did the cleaning for $1200. they have a machine.
    you would think that if your dealer, you'd have the all the equipment needed to service trucks. specially since dpf's have been out 8 years now. but apparently it's too expensive for the vegas dealer to buy.
  11. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    in Detroit area,$200 for basic cleaning.$500 if it has to be "baked"24 hr.turn around time.
