Regen Issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by HopeCartage, Dec 19, 2024.
  1. HopeCartage
    HopeCartage Bobtail Member
    I have a DD15 Detroit Diesel 2009 Western Star Dump Truck. My issue is excessive Regen and Truck Derates? Has any body that issue and is there a fix.
  3. 062
    062 Road Train Member
    6,282
    33,792
    Oct 20, 2013
    Need to know what codes it throwing.
  4. HopeCartage
    Thank you for the reply, Don't have a code reader.
  5. HopeCartage
  6. 062
    6,282
    33,792
    Oct 20, 2013
    You need to find out what the codes are,then most likely you’ll have to have DDDL8 to get it out of derate after repairs are made.
  7. Heavyd
    Heavyd Road Train Member
    7,808
    6,258
    Feb 4, 2009
    It is likely, at the least, the dpf needs to be removed and cleaned and then flow tested to see if it can be reused. Frequent regens can be signs of aftertreatment components nearing end-of-life. DPF, DOC's and other related parts do degrade and do no last forever. If you are seeing any white or greyish coloured smoke, that is a sign the DOC is degraded and may not be making proper temps for a successful regen to complete. You may also have an engine air handling issue, such as failing egr valve to also cause this. There situations where the problem isn't causing a fault code, but you do experience this symptom first. Your next steps are getting the regen quality, engine health and DPF restriction tested.
    Oggie, 062 and AModelCat Thank this.
