Regen problem
Discussion in 'Volvo Forum' started by charlie747, Jul 4, 2015.
  1. charlie747
    charlie747 Bobtail Member
    14
    May 24, 2015
    I get a the light to do the regen and i do but after 1 1/2 hour and finish the light still on and the soot level gauge stiil at level 3, i do the process 2 times and nothing
    Help please!!!
  3. Getsinyourblood
    Getsinyourblood Road Train Member
    1,273
    1,803
    Jul 5, 2014
    Retired. North Texas
    With a Freightliner, you have to have the coolant to the Max Cool line on the coolant reservoir, or you may not achieve a proper ReGen. I can't speak for a Volvo. Where is your coolant level?
  4. charlie747
    14
    May 24, 2015
  5. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    A bit more info about the truck might help, year, engine make, mileage, etc.
    Sounds like its not getting the dpf inlet temp high enough to actually do a regen. Thats usually a sign of a Doser injector problem or a problem with the dpf inlet temp sensor.
  6. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    i have had a problem were i have had to do 3 or 4 regens in a row. that usally does the truck
  7. charlie747
    14
    May 24, 2015
    I have volvo 2012 780 d13
    600,000 miles
    I check the temp is 580 to 640F when I do the regen parking, after finish the gauge still at 3, when I star driving the gauge star going down to 0 and then in a secons back to 3
  8. KeithT1967
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Sounds like a sensor problem then.
  9. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Sensor issue probably
  10. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    with those kind of temps you aren't dumping any fuel in the exhaust to get it to burn hot enough. Most likely cause is the DPF doser located on the back side of turbo probably its plugged truck is trying to regen but not burning hot enough to get rid of soot might need to clean and replace gasket might need new doser or controll thats the only thing i can think of from the top of my head.
    daf105paccar Thanks this.
  11. justsomeguy
    justsomeguy Bobtail Member
    16
    12
    Jan 29, 2015
    If you're good with a wrench pull the 7th injector and inspect the inside of the pipe / chamber it sprays into - my buddy's truck packed soot in there regularly, restricting the spray of the 7th injector and basically making every regen attempt, parked or rolling, super inefficient. He described cleaning it as annoying but not really hard. Some carb cleaner and a stiff wire brush or glove finger (probably want to throw the glove away when you're done) would do it.
    If you are good with tools, this is an easy thing to check and fix if it is the problem, or cross off the list of potential problems if it's not severely sooty.
