regen problems!!!
Discussion in 'Ask An Owner Operator' started by missjhawk, Oct 2, 2018.
  1. missjhawk
    missjhawk Medium Load Member
    571
    324
    Jul 24, 2013
    nutbush
    I recently bought my 2nd trk.
    2013 587 peterbuilt 400,000 cummins isx 450st
    Immediately I started having regen problems
    Dealer say I was backed up from truck sitting before I bought it
    Had doc cleaned
    Def filter baked $1200
    Billows exhaust leak $750
    Def Rail fuel line leak and had def fuel injector tested and cleaned $650
    Exhaust leak on both ends of def catalyst $450
    Exhaust leak on muffler $350
    Boost pressure sensor and imap sensor $300
    Tempreture sensors $650
    THE MAIN PROBLEM
    Bad def fluid injector and def pressure sensor on catalyst $1100
    Doc and filter cleaned again $1200
    This is not including all the countless forced regens I had to pay for at $150-300 each time
    After all that my truck is finally doing right I got good horsepower compared to before my mechanic said give truck 3 months to finish getting back to 100% but I'm happy now it took me 4 months to get where I am right now
    Hope this help someone if you see my headache of def problems being in and out of shop is no fun especially when I only had truck since 1st of may this year
  3. JonJon78
    JonJon78 Road Train Member
    7,216
    42,542
    Jul 1, 2018
    I just replaced the 2 sensors that you replaced for half the cost... Price was $150 for both sensors... One if them used one bolt the other two bolts, certainly shouldnt cost $150 to unscrew 3 bolts and plug a sensor in.
    Dealerships are called stealerships for a reason.
  4. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    I don't know who your machanic is, but he's not doing you any favors. I'd look for someone else.
    God Bless You! and Good Luck!
  5. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    My gosh! I'm think'in I should open my hood and give my old 6nz a big hug. Hopefully you will have many trouble free miles now!!
    Trugo, RSB34 and shogun Thank this.
  6. missjhawk
    571
    324
    Jul 24, 2013
    nutbush
    My mechanic don't work on def I had all my work done at kenworth and peterbuilt in Memphis tn
    fargonaz Thanks this.
  7. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    It really helps if you can do the work yourself, most mechanics are incompetent nowadays they just dance around the truck and want to get paid top $.
    To keep the DEF clean I use a bottle of diesel injector cleaner on a full tank (35 gallon tank on a Ford F-350 pickup) right before I change the oil. I use Shell Rottella T6 synthetic oil exclusively and go 15,000 miles between oil changes, the truck now has 310k miles and the DEF system is all original. Dura Lube has a product called DEF Reducer Kit now at Walmart, I just tried it out on a new-to-me Dodge Ram 3500 pickup with 150k miles and it seems to work I can tell from the exhaust smell. Before I use DieselCleen and BG products.
  8. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Chk out a filter for the cummins engines called the dorthy by Pittsburg power...Dorothy EGR
    Those engines run fairly dirty I hear so seeing you spent all that $ once,a lil more to save you that again will always be worth it..
  9. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    I think you mean you had your DPF filter baked not your DEF filter.
    Btw did you have your DEF filter replaced?
  10. RSB34
    RSB34 Light Load Member
    277
    198
    Feb 9, 2013
    ny.
    Sure fire way to fix regen
    1 sell the truck
    2 buy pre emission truck
    3 rebuild old truck so it's reliable and be glad you won't have regen problems.
    Trugo and DieselDrivinDaddy Thank this.
  11. ast26909
    408
    264
    Mar 1, 2018
    With proper care the DPF should give no problem, here are my experiences and tips based on my observation. I notice that my truck uses more DEF fluid with the B20 diesel (20% bio-diesel) than B5 (5% bio-diesel) so I seek out B5 avoid B20 wherever I can, most regular gas stations have B5 vs most truck stops (Love's, Pilot...) have B20. I use synthetic oil exclusively because it's much better than conventional dino oil for engine protection and produce less soot & deposit the best way to control soot is to generate the least of it in the first place. Every 10-15 thousand miles I run a tank with injector/DPF cleaner, this will keep the engine clean and the soot down. It costs me about 4 gallons of DEF fluid (about $10) for every 10,000 miles plus another $10 for the additive cleaner, this is very reasonable to keep the air clean. I'm not a tree hugger but I do what I can to leave a livable earth for my children, this rock we're living on is the only one we've got.
    uncleal13 Thanks this.
