reitnauer broke frame
Discussion in 'Ask An Owner Operator' started by renegadetc1, Dec 14, 2013.
  1. renegadetc1
    renegadetc1 Bobtail Member
    i am not a heavy hauler just legal loads and yesterday found both frame rails are broke on my 2007 step deck. is this common for rietnauer trilers ? always thought they were top of the line trailers.
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    alum. only flex so many times before they crack.
  4. bergy
    bergy Road Train Member
    1,189
    1,311
    Nov 1, 2013
    Is this a very hard / expensive thing to repair?
  5. baha
    4,137
    2,836
    Jul 25, 2013
    ga
    trailer shops can fix,or back to factory for fix. I have taken one back in 2005 to fac. they found at one time someone put tie/downs under frame then over load, they said it changed the way frame flexed, an caused breakage.
  6. renegadetc1
    i understand that but know of 1998 trailers with no cracks who haul with me. i cannot believe my 2007 cracked to such a severe level already. anyone know if reitanauer will stand behind this ? seems this trailer is to young to be falling apart.
  7. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    Hmm, maybe a bad batch of aluminum that it was built with. I never go with a 100% guarantee of "if" but when, how and where something will fail. It's just a chance that's taken no matter what you purchase. I would see if if they will replace the rails. No way in hell would I ever trust a repair weld in a high stress area that would flex such as the main beams. Others maybe ok with it but I'm to #### paranoid of the failure factor of what could happen if the trailer failed under load at 65mph but that's just me.
  8. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    You are right about welds, they don't flex. I know, some guy who welds is going to say "my welds will flex"… No they will flex for a while but only half as much and half as long as virgin aluminum. You can fish plate them for a temporary fix. I would insist on the plates (both sides of each crack) being twice as far out as the crack is long. In other words, if the crack is six inches long then put a two foot fish plate on it. If you can't get that much plate, replace the rail. You DO NOT want to be shut down at Banning for that.
    Skunk_Truck_2590 Thanks this.
