relay valve still leaking air??
Discussion in 'Kenworth Forum' started by boilermaker1978, Dec 31, 2013.
  1. boilermaker1978
    boilermaker1978 Bobtail Member
    12
    Dec 10, 2013
    I have a 1997 kenworth t800 and cannot figure out why my relay valve is leaking air ?I replaced this valve (new) still leaking.I was told i have a blown brake maxi.There was one leaking i replaced that still leaking air out of the bottom of relay valve.It only leaks air when tractor brakes are released of coarse.If anyone has any suggestions i could use the help Thanks!
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    many valves are bad out of box, unhook EM MAXI.air lines till leak stops?
  4. boilermaker1978
    12
    Dec 10, 2013
    i just put valve on and replaced the leaking maxi thats far as i got.well i should say the valve was a reman its all they had on hand.
  5. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    i have put on 4 bad out of box.{china remade}
    boilermaker1978 Thanks this.
  6. snowwy
    snowwy Road Train Member
    20,594
    13,315
    Jul 6, 2009
    have you been in a warmer climate???
    i've been in 2 trucks i'm thinking might need new dryer filters. they don't leak when in the south. but come back up north. and my tanks will be empty in 10 minutes.
  7. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    You still may have another bad maxi. The air is leaking through the center of the maxi from the spring brake side, and going back up the service line and out the exhaust of the relay valve. Either take off the service lines from each maxi one by one to find your culprit, or pinch off the air line to the spring brake side one by one. Now, I did have this truck years ago with this very same problem. The truck sat for about a year. Once the brakes were released for the first time after sitting, ALL 4 maxi's leaked!!! I removed the service line and from all of them to confirm. Just dry rot/rust of the center seal inside.
    04 LowMax, baha and boilermaker1978 Thank this.
  8. boilermaker1978
    12
    Dec 10, 2013
    Thanks for the info ill try this.Ive been in awful rainy and snowy weather temps in the teens.If that dont help with the maxis ill take the valve back and try a new one.
  9. Bill1974
    Bill1974 Bobtail Member
    I have the same problem on my 1998 freightliner.Where are the maxi brakes located on it so I can check them first before I return the new relay valve I just installed?
  10. snapon tools
    snapon tools Bobtail Member
    hey so my quick release air brake valve leaks air.. I removed all the brake pot service lines and the valve was still leaking air. I replaced the valve and it still leaks air. I ordered and installed another new valve and its still leaking... anymore ideas????
  11. snapon tools
    its a 2009 Peterbilt 367
