Relay with OOS defects....
Discussion in 'Schneider' started by RootHog, Mar 11, 2017.
  1. RootHog
    RootHog Heavy Load Member
    747
    868
    May 23, 2008
    NWA
    So, I have a relay to pick up in Dallas. It was at the yard in Laredo, and had to be checked there for road readiness. It was apparently good enough to leave there.
    It bypassed the Dallas OC where it should have went if it had problems, but dropped at the atomic drop yard in Dallas.
    No idea what is wrong with it, been on hold for almost an hour, including calls being dropped after sitting on hold forever.
    If this was placed OOS for a stupid reason, are we able to still pull them, or is the trailer down until a mechanic checks it out?
    Honestly don't think I have ever picked up a relay with an OOS defect.
    Taking this load home to deliver on a Tuesday, gonna suck if it can't go because everything is taken at this point in the Dallas area.
    Might be looking at a 350 mile deadhead home....
  3. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    You waited an hr a while longer isn t going to kill you.My guess would be trailer is on a safety hold.
  4. RootHog
    747
    868
    May 23, 2008
    NWA
    Thank you for that totally useless reply
    Cledus Snow, Thull, 88 Alpha and 3 others Thank this.
  5. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    you're very welcome
  6. TennMan
    TennMan Road Train Member
    7,866
    9,658
    Sep 21, 2011
    Hazzard County Jail !!!!!
    Check the inspection dates within 30 days I believe the system puts automatic OOS to force it by a shop.
    If you pre trip it and can't find why it's OOS I'd roll with it. As long as it passes pre trip.
    Friday Thanks this.
  7. TennMan
    7,866
    9,658
    Sep 21, 2011
    My guess is it was cleared in Laredo but the system wasn't updated. If it came from the yard and not a freight forwarder.
  8. RootHog
    747
    868
    May 23, 2008
    NWA
    Driver dropped it and put it OOS it seems. Level 9 brake repair, whatever that means.
    So, once I get my local load loaded and dropped, heading over to the atomic drop lot and seeing what's up with it. Nothing else to do here in Dallas at this point, so either dragging that trailer home with me, or deadheading. Be home tonight one way or the other, lol.
    Just pisses me off that it would be taken out of a OC, bypass another OC, and dropped at a drop lot with mechanical problems. People need to use their heads, this could have easily been routed to the Dallas OC, and if the brakes are truly messed up, it never should have left Laredo.
    ExOTR, Friday, drvrtech77 and 2 others Thank this.
  9. TennMan
    7,866
    9,658
    Sep 21, 2011
    Sni should've never opened the gate which leads me to believe it wasn't at the OC. But you never know
  10. stevep1977
    stevep1977 Road Train Member
    3,704
    22,548
    Dec 23, 2010
    Chicago, IL
    You're assuming Dallas would actually fix the problem if it was at the OC. I've never had any work done at that facility because every time I've requested work to be done on my truck they'd say they can't even look at it for 3 to 4 days. They're probably worse than even Atlanta.
    Friday and TennMan Thank this.
  11. gentleroger
    gentleroger Road Train Member
    7,657
    20,736
    Jun 1, 2010
    To be fair the driver may have only noticed it as he did the post trip.
    I've had trailers pass the pti but when I get to the drop point I've developed a leak.
