Releasing trailer brakes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wlhequipment, Oct 24, 2024.
  1. wlhequipment
    wlhequipment Bobtail Member
    42
    17
    Aug 16, 2022
    denver, co
    This is definitely a rookie question. I have a customer who has a couple trailers on his yard he just uses for storage. He asked me to release the brakes today so he can move them with a forklift. I had a couple glad hands, so I plumbed my compressor on my truck into them both. About 120 psi. I didn't hear major leaks, the tank had air, I assume the full 120. The brakes did not release. I was just going to take the tension off the cans and pull the clevis pins out and leave it like that. But they wouldn't release. What did I do wrong?
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,928
    Oct 31, 2023
    The system needs constant air once charged. The brakes will set again once you detach. Tell the trailer owner to cage the cans to release the brakes. No need for air.
    Oxbow Thanks this.
  4. snicrep
    snicrep Road Train Member
    1,160
    2,105
    May 13, 2009
    mcallen, tx
    You can just uncage them with a socket. Inside the brake chambers. Pop open the plastic plug in the middle. Google it. Everyone should know how. I've had to do it twice. Busted a brake airline twice.
  5. AModelCat
    159,112
    Trailer supply line needs to stay charged with air or the trailer park brakes will stay set.
  6. Animosus
    Animosus Heavy Load Member
    715
    2,807
    Dec 7, 2015
    SE Wyoming
    If they have been sitting for that long very possible the shoes are stuck to the drums also.
    skallagrime and Oxbow Thank this.
  7. wlhequipment
    42
    17
    Aug 16, 2022
    denver, co
    Thanks all, but my real question is, why didn't the brakes disengage? With 120 psi in both the red and the blue line, and no major leaks, shouldn't those brakes have released?
  8. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    157
    263
    Jun 24, 2017
    Applying air to red releases brakes, blue applies them. Just supply the red side.
    wlhequipment and AModelCat Thank this.
  9. AModelCat
    159,112
    Both pressured at the same time? No. The park brakes would release but the service brakes would be applied.
    Just pressure up the supply line.
    Rugerfan and wlhequipment Thank this.
  10. Iamoverit
    2,159
    4,928
    Oct 31, 2023
  11. wlhequipment
    42
    17
    Aug 16, 2022
    denver, co
    Thank you! That's what I needed to know.
