Removing adhered placards from shipping container
Discussion in 'Experienced Truckers' Advice' started by Captain_Lewis, Dec 11, 2018.
  1. Captain_Lewis
    Captain_Lewis Bobtail Member
    Whose responsibility is it to remove the placards from a container after offloading?
    Where can that rule or guideline be found?
    What is the most efficient & safe way to remove these placards when temperatures are below freezing?
  3. SteerTire
    SteerTire Road Train Member
    1,414
    2,346
    Nov 5, 2018
    Behind the wheel
    You’re responsible. And a propane touch works great. A little heat, off it comes. Or, if you can find a good 18 or 24 volt paint remover. That would be ideal also.
    JonJon78 and RERM Thank this.
  4. Captain_Lewis
    So the driver is responsible?
    What type of paint remover are you referring too? (Sander, Oscillating tool, grinder)
  5. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    You ever been into a Lowe's store before? They need to change your name to Captain_Obvious... Use this and some WD-40... itll come right off there.. Wagner Heat Gun...
  6. RERM
    RERM Road Train Member
    1,683
    1,125
    Dec 13, 2012
    Chicago, IL
    JonJon78 Thanks this.
  7. Captain_Lewis
    I appreciate the help and kind words Gdog66223 ;-)
  8. Gdog66223
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    Your welcome... ANYTIME!!!
  9. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Removing placards is the responsibility of whoever unloaded the hazardous goods from container/trailer if you can find them:D
    Paint or duct tape the quickest way to deal with adhesive placards.
  10. Chinatown
    Chinatown Road Train Member
    76,721
    178,600
    Aug 28, 2011
    Henderson, NV & Orient
    That's what I used.
    I'll give it a feeble, half-hearted chance to peel off, and then spray paint it.
