removing bed from truck
Discussion in 'Expediter and Hot Shot Trucking Forum' started by michaelaland, Feb 18, 2016.
  1. michaelaland
    michaelaland Bobtail Member
    48
    8
    May 16, 2015
    anyone who has removed the bed from their truck, where did you get the tail light replacements? can t seem to find a kit...also any other suggestions for the conversion such as mud flaps etc... thanks
  3. pallet breakdown
    pallet breakdown Bobtail Member
    42
    22
    Feb 13, 2016
    I buy an egg crate from Wal-Mart and roll it out over the mattress then put sheets on over it
  4. michaelaland
    48
    8
    May 16, 2015
    what are you talking about? im talking about the tail light replacement for when you remove the bed(box) off your truck
  5. Bean Jr.
    Bean Jr. Road Train Member
    5,480
    9,717
    Mar 30, 2014
    Are you putting a different bed, or converting it to be a tractor?
  6. Ridgeline
    22,150
    113,561
    Where to get lights?
    Walmart, any trailer shop. Any lights will work, even those fancy truck lights. The plug may be an issue but if you have a setup for a trailer, just use that.
    By the way. I bolt a piece of wood across the frame and put lights on that. I also put mud flaps/minifenders on because there is nothing worse than having a very pissed off person ram your truck because you just sprayed them with rocks.
  7. americanmadetrucker
    americanmadetrucker Logistical Engineer
    896
    3,279
    Jul 3, 2012
    Memory foam works great. Sleep like a rock!
  8. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    This guy is talking about a pick up truck bed not a sleeper cab mattress
  9. michaelaland
    48
    8
    May 16, 2015
    converting it to tractor....
  10. michaelaland
    48
    8
    May 16, 2015
    I see so your plugging the lights into the trailer receptacle and not hard wiring them into the original light wiring harness? As for the piece of wood across the frame, I have seen that with the mud flaps attatched... I think I am going to fabricate myself some quarter fenders and do it that way....
  11. Ridgeline
    22,150
    113,561
    Yeah unless it is not a temp install, I would just use the trailer plug.
    michaelaland Thanks this.
