Removing drive shaft for better fuel economy..
Discussion in 'Ask An Owner Operator' started by joseph1853, Sep 5, 2021.
  1. not4hire
    not4hire Road Train Member
    7,142
    26,950
    May 16, 2012
    Calgary
    When I want to increase fuel economy I just call a tow truck.
  3. joseph1853
    joseph1853 Heavy Load Member
    992
    553
    Dec 12, 2010
    Waco, TX
    lol.
  4. Rideandrepair
    16,526
    53,944
    Aug 8, 2015
    What you’re describing is a tag axle. Basically a single axle Truck with an extra axle on the rear. Holland used to run them. The idea is to save fuel and tire wear. Still be able to scale Heavier loads when needed. They used to run like hell through the snow and ice, with the tag axle up, having the extra weight on the single drive, gave them better traction. Works great, till it doesn’t. Just a way to save money, specing a Truck.
    joseph1853 and Speed_Drums Thank this.
  5. ProfessionalNoticer
    2,941
    7,844
    Apr 25, 2021
    Maybe they run different types of suspensions? I've gotten stuck with single axle day cabs many times on the dumbest things like ice, mud and small slopes. It happens with my tandem too but a simple flick of the power divider switch on the dash gets me out every time.
    joseph1853 Thanks this.
  6. ProfessionalNoticer
    2,941
    7,844
    Apr 25, 2021
    Why do the tires on the back axle wear down faster than the front of the tandem?
  7. bavarian
    bavarian Heavy Load Member
    727
    781
    Feb 13, 2014
    Winnipeg
    You sound like you've learned something. There ain't many of that kind.
    Roger McG Thanks this.
  8. GYPSY65
    GYPSY65 Road Train Member
    1,938
    5,218
    Nov 16, 2012
    SW FLA
    Do you get a fuel discount where you are at?
    If not, look into getting one like NASTC
    It will save you a significant amount on fuel
  9. Lyle H
    Lyle H Road Train Member
    1,194
    2,599
    Apr 16, 2014
    Because of the increased scrubbing effect on the rear axle when turning.
    joseph1853, Roger McG and Snailexpress Thank this.
  10. lester
    2,821
    7,480
    Jan 2, 2012
    NW, Iowa
    I am not positive but I believe the right rear will always wear the worst. Has to do with the flow of power through the rear axles. Right rear will be the one that wants to spin first.. in my experience anyway.
  11. TallJoe
    TallJoe Road Train Member
    7,490
    16,266
    Apr 12, 2016
    Chicagoland
    Volvos from 1998-2003 were vulnerable to lose that shaft. I lost it twice myself, on two different trucks. Some removed it but not so much for fuel economy but for savings in repairs.
    I want to have it. On some occasions, I was hanging on a bump and during winter on a slick spot, sometimes at a dock where its driveway grade was awkward, it did help to move out. The idea to remove it in order to gain mpg is not very good.
