Removing greasless 5th wheel plate
Discussion in 'Ask An Owner Operator' started by skman, Oct 25, 2022.
  1. skman
    skman Medium Load Member
    313
    133
    Aug 26, 2013
    Saskatchewan
    I bought a truck that has a silicone? plate on the 5th wheel. It's in rough shape and has been greased.
    I want to remove it and leave it off because we're on different company trailers quite often.
    Can I take it off and just use the 5th wheel plate as-is? Or would the few tiny bolt holes be an issue with DOT? I could put sunken bolts back in....but i haven't pulled the slick plate off yet to see if that's possible.
    With two motor rebuilds on the horizon...I don't really want to spend $1500 on a new plate right now if I can still use this one.
  3. Tb0n3
    Tb0n3 Road Train Member
    4,739
    9,658
    Oct 5, 2012
    Earth
    It's teflon, and I can't imagine the replacement parts are that expensive. My guess is it wouldn't work too well without the pads in place. Not to mention the jaw alignment will be off if it drops by however thick the plates are.
    Actually now that I think about it they could just be HDPE. It's pretty common in lots of industries. Basically milk bottle plastic.
    Rideandrepair and skman Thank this.
  4. Siinman
    Siinman Road Train Member
    5,533
    14,237
    Mar 5, 2017
    Kansas City, MO.
    I would think you can just put the bolts in and counter sink them if they are not already. If you do that you should use some lock tight on the bolts so they do not back out on you. I would also say that the DOT is not gonna look at your 5th wheel either so it should be fine either way.
  5. skman
    313
    133
    Aug 26, 2013
    Saskatchewan
    I checked out the prices online...looks like $500...and it'll get trashed with grease from the company trailer swapping
    Rideandrepair and Siinman Thank this.
  6. Tb0n3
    4,739
    9,658
    Oct 5, 2012
    Earth
    What do you mean trashed? It's plastic. You just don't have to worry about it. Grease doesn't hurt it.
    Rideandrepair, Cattleman84 and skman Thank this.
  7. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,458
    6,865
    Oct 22, 2016
    North Dakota, Eh?
    We have those on our Hollands. Boss specs the trucks like that. But still have to put a couple squirts of grease on it. I'd replace the pad and roll on rather than the whole plate.
  8. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Those pads are serviceable. Simply change them. Grease doesn’t hurt them.
  9. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Last plate I had a plastic (hdpe?)plate bolted over top and now I have a Teflon plate . I still like grease on it. Doesn't have to be a lot but some. Especially on that plastic bolt on plate. It would bind up a bit if it was completely dry
    Rideandrepair and Crude Truckin' Thank this.
  10. Cattleman84
    Cattleman84 Road Train Member
    10,039
    71,741
    Nov 1, 2017
    The Sticks, Idaho
    Replace the pads and run it... Grease dont hurt them a bit.
    I swapped trailers 3 to 5 times a week for 5 years, used 2 sets of pads in that time... They went on white and came off black... Both time they needed replaced because they caught and rolled up while picking up low dropped or sunken trailers, other wise they were still servicable.
  11. Kairen0001
    Kairen0001 Light Load Member
    109
    120
    Dec 17, 2021
    Rideandrepair Thanks this.
