I am in the process of removing this from outside of my truck, I cut the plug off the end of the wires so I could thread it down the back of the cab, now I am getting a code...not sure what it is...does anyone have a clue?
Removing qualcomm and tracking system from 2003 Volvo
Discussion in 'Volvo Forum' started by JBryant, Aug 17, 2013.
Why didn't you just unplug the dang thing?? Sooner or later you might need to have one!
Not going to need it and tired of washing around it.
I sure hope this isn't a company truck...
Aside from that, how will anyone know what the problem is... without giving the code? -
It is not a company truck, it is my truck...the code is a symbol that sort of looks like a man seated wearing a seatbelt with an octagon shape in front of him
ck at fuse box pull 2wires they added will / stop code
Any idea where these would be located in the fuse box? The reason I thought it safe to go ahead and remove this, is that when having a/c work done we noticed that alot of the wire had already been cut under the dash, so I was just going to go ahead and take it off. After cutting wires I noticed that the gauges would not work after cranking, so I spread the wires apart where I cut it, then the gauges would work but the code came up
Get a bigger set of dikes.
Hah, I'd check instrumental cluster parameters (list on module IDs to check)
