Removing stains inside reefer trailer walls?
Discussion in 'Ask An Owner Operator' started by PE_T, Jan 21, 2019.
  1. PE_T
    PE_T Road Train Member
    What could I use to clean stubborn stains on the walls of my reefer trailer without discoloring the white walls? I bought some 409 spray, and haven’t used it yet, but I am beginning to think it won’t work.
    The inside walls appear to be made of some type of flexible (?) fiberglass.
    Reason for edit: More info.
  3. TruckRunner
    TruckRunner Heavy Load Member
    704
    3,270
    Dec 21, 2017
    Did they say you had to clean them or you just doing it for the heck of it? That's a good question I never had any issues with stains on the walls of any reefer trailers I pulled for eight years. I know bleach cleans everything did you try that? Worst case scenario you could always just paint them.
  4. PE_T
    Hahaha. No, I had no issues with a shipper. I happen to have a brand new trailer, and I am starting to see more and more stains appear. I cleaned the walls a bit with Windex some 3 months ago, but it was no match for the stains. It did remove some dirt, especially on a section of the trailer shute that had strangely accumulated some dirt. I’m guessing a bleach cleaner could not damage the white wall.
  5. TruckRunner
    704
    3,270
    Dec 21, 2017
    In that case perhaps a pressure washer would do the trick
    Lepton1 and PE_T Thank this.
  6. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    Dollar store sells a product called Awesome,mild acid,cleans anything.Don't get it in your eyes.
    DoneYourWay, PE_T and TruckRunner Thank this.
  7. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    Vinegar is a great thing to have. I always keep at least a quart in my truck. It's nontoxic.
    Sirscrapntruckalot and PE_T Thank this.
  8. 062
    062 Road Train Member
    6,215
    33,462
    Oct 20, 2013
    If a scrub brush doesn’t work use a blue scotchbrite.
    PE_T Thanks this.
  9. Ridgeline
    22,394
    116,378
    What are the stains from?
  10. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
  11. PE_T
    No, not at all.
    Blue stains, probably from blue chep pallets, and also black stains from load locks. The rest are maybe coming from pallet packaging/boxes.
