Renting a truck for D road test in Ontario
Discussion in 'Canadian Truckers Forum' started by dav13, Dec 21, 2024.
  1. dav13
    dav13 Bobtail Member
    28
    Mar 13, 2024
    Hello,
    On some posts people say the 26 FT U-Haul truck works for the road test but other posts say it doesn't work. Does anyone know the correct answer?
    Says D class truck has to be gross weight of more than 11,000 kg (24,000) lbs
    U-Haul truck is 25,999 lb gross weight.... says under 25,999 lb gross weight on the truck door
  3. Ind0792
    Ind0792 Light Load Member
    111
    110
    Oct 14, 2018
    Wouldn't it have to have air brakes?
  4. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,405
    2,389
    Jan 7, 2023
    Yes, it would need air brakes, and need to be registered for the extra weight. Also, if it required a license that you do not have, they would not rent it to you (spoiler alert: EVERY truck U-Haul has can be driven with just a regular car license). Furthermore, truck rental companies don't rent trucks out for road tests....
    Sorry, Charlie; this was a hare-brained idea.
    Peplow Thanks this.
  5. NorthEastTrucker
    NorthEastTrucker Heavy Load Member
    889
    1,551
    Sep 21, 2019
    Never seen a Uhaul truck with air brakes on it yet.
  6. dav13
    28
    Mar 13, 2024
    It doesn't need to have airbrakes because I'm only doing the D class test... not DZ test the Z part only requires air brakes
  7. dav13
    28
    Mar 13, 2024
    Doesn't need airbrakes because Its a D class test not DZ test......
    Seems like uHaul works because the registered gross weight is 25,999 lbs
  8. Peplow
    Peplow Light Load Member
    80
    149
    Mar 28, 2010
    Ontario
    What do you plan on driving that doesn't have air brakes?
    Pete
  9. dav13
    28
    Mar 13, 2024
    I already have a Z license...
  10. Peplow
    80
    149
    Mar 28, 2010
    Ontario
    The truck will still need it for the pre trip part of the road test?
    Pete
    Ind0792 Thanks this.
  11. Ind0792
    111
    110
    Oct 14, 2018
    But they would need to have air brakes for the pre-trip portion of the test, no?
    Call up a Drive Test centre and ask them.
