replacing a foot valve
Discussion in 'Trucks [ Eighteen Wheelers ]' started by thesvg, Jan 23, 2011.
  1. thesvg
    thesvg Light Load Member
    192
    13
    Dec 9, 2010
    Hey guys, I recently noticed a slight leak (not leaking over 2psi) but I can hear it and so can DOT :D but its comming from the foot valve, but I sprayed some soapy water on it, and its a giant green hose thats leaking at the nut, I'm tempting to tighten it but am afraid to pinch the hose and make it worse.
    any suggestions?
  3. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    if you have enough slack and you know it is leaking at the nut and not where the brass nipple screws into the foot valve. get a new ferrule and nut and cut the line a half inch or so back and put it back on. cheap and easy, good luck.
    thesvg Thanks this.
  4. cavegunner
    cavegunner Bobtail Member
    30
    Aug 26, 2011
    I just put an '88 cab onto an old Star. The wrecking yard cut the air lines with a torch. I'm having to sort out a melted mess all the way back to the foot valve. The outlets are all labeled "supply#1 through #4". Where do these supply outlets go? Also, where does the foot valve get it's air from? I haven't been able to find a plumbing diagram for a Volvo-White valve. Any help would sure be appreciated.
  5. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    See Bendix air brake handbook for complete schematics of air systems.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    dont forget the sleve that goes inside the line also!
    country29 Thanks this.
  7. country29
    518
    157
    Feb 27, 2010
    yea, some have the sleeve, some it stays on the nipple, just got to figure out which 1 it is!
