I have a super 10 that is about worn out. I have a 1985 Freightliner cabover that has been parked for about 20 years. It has a 9 speed 12609 transmission. I know the 12 refers to torque rating. My super 10 is a 14610, with a 14 torque rating.
My question is not about the torque rating. My question is, will it fit?
Are the bolts in the front the same?
I figure the front shaft may be smaller, but I don't know that yet.
The clutch should still be good in the old 85.
Can I swap the two transmissions, clutch and all?
I was told that it's easy and relatively cheap to turn the 9 speed into a 13 speed by adding a backbox. I'd like to do that.
Does anybody here have any experience doing something like this?
How about the shifter? The cabover shifter is different from a conventional.
replacing a super 10 with an old transmission
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by stonefly4, Dec 27, 2019.
13spd is a direct swap drive shaft is the same size
Bad idea. Super 10 is about 30% OD and your 9 spd is no OD. 13 spd is maybe 12% OD. Will your gearing allow you to slow down that much?
You can google Eaton or Fuller or Road Ranger? transmission rations. There is a list of all transmissions, length, ratio etc.
I personally never liked driving a super 10 except the one with 9 & 10 auto shift. That was great in rolling hills. Thank something like a RTLO15210C is a direct replacement if the shifter is in the correct location. If you like the S10 probably just get a reman.
I know where a used RTLO is with less than 10,000 miles on a reman. Man wrecked his truck. Videoed the engine running ( C15 with a million 3 on it ) and put it up for sale. Man said he would buy it. Owner paid a mechanic and a wrecker to pull the engine and trans. Man was a no show. I am not buying or selling anything but PM me if you are interested. I can put you guys together.spsauerland and stonefly4 Thank this. -
I don't like the super 10. It's been dependable, I have to say that, but waiting for it to shift is too much of a PITA. I'd love to be driving a 13 speed.
As far as the torque rating goes, I can easy pedal the truck. I've never been one to get down hard on a truck. -
Transmission will bolt right in with the clutch you have. Clutch may not swap and would probably be undersized. Is shift tower location correct? Cable or electric speedo? U joint - yoke size?
stonefly4 Thanks this. -
I'd have to deal with that.
I think they're both electric speedo. I'll have to have another look at the old cabover.
The project may turn out to be more trouble than it's worth.
It's just that the super 10 is about worn out and I don't want to replace it with another super 10.
I have prices on a 13 speed or an 18 speed, both reman—$5,000 and he doesn't want the super 10 for a core. $3,000 if I'll settle for another super 10.
The other day I had the thought about the 9 speed in my cabover. I wouldn't mind the trouble and expense of upgrading it to a 13 speed, but if the speedo won't work, the shifter won't work, the clutch is too small, and the yokes are different size, then by the time you add in the labor and down time I might just as well hand the keys to my local dealer and tell him to install the 18 speed and I'll pick it up in the morning. -
I believe I'll yank that transmission out of there just for the sake of getting it into the daylight. It's been sitting there for 20 years. -
They both have a 2 inch input shaft. I thank the smaller 1 3/4 shaft went out with the 9 series transmissions.
The shifter location I was referring to is where the tower bolts on top of the transmission. It could be in the center, forward or to the rear.
Then the bottom of the stick can be different.spsauerland and starmac Thank this. -
What box car said, and it would be easy enough to make sure the trans has the right top plate before you pull it out of the cabinover.
With regard to the yoke, I have a torch and a welder. I think I can deal with that.
