replacing air compressor
Discussion in 'Trucks [ Eighteen Wheelers ]' started by heavyhaulerss, Oct 10, 2014.
  1. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    in the near future, I will replace my compressor. I think I have a bendix 550 truflow. is there one available that would build up air pressure faster? to help make up for the leaks I have? is there a btter brand than bedix? the last one had leaks not more than 1 year after installation.
  3. kwswan
    kwswan Road Train Member
    1,989
    10,772
    Jul 26, 2009
    mcminnville,tn.
    Not trying to be a jerk but you would be better off fixing your leaks than trying to put a bigger compressor on.
  4. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    hey what's with all the thanks to this post?:biggrin_2559: yeah your correct. no offense taken. just trying to find leaks are sometimes difficult. but I am not replacing just to keep up with the leaks. it's just that time so I am looking if there is something better. when I went to buy my air gov the truck pro employee recommended the new type with the blue cap. it is not adjustable like my old one, but I like it better. it builds more pressure & helps when I have to air tires. had several punctures this last year, fixed all myself right on the spot.
  6. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    You may look at TU FLO 750. But this is more expensive compressor. I think they all manufactured by Bendix...
  7. marmon96
    marmon96 Light Load Member
    98
    57
    Dec 27, 2013
    gardner,ma.
    you gotta be kidding me,:biggrin_2559::biggrin_2559::biggrin_2559: am i gonna be the first to say it.........................................."WHAT AN IDIOT":biggrin_25513:
  8. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Your compressor might last more than a year if it didn't have to run constantly to keep up with your leaks
  9. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    ill be watching this thread as well. not that i have bad air leaks i mean my truck does leak some air but not enough to matter takes about 6 hours for the system to drain down after shutting the truck off. witch is far less than the 2psi per min single 4psi per min combination requirement by dot.
    but i would be interested in a higher flow compressor mainly for when im pulling my belly dump. has a huge air tank on it that takes for ever to fill if the trailer has been sitting around long enough to bleed down, and they use a ton of air to charge back up after you dump a load.
    btw you know you can set a adjustable regulator at the pressure you want, i have just a regular governer on mine and i adjusted it from 120 to 135. take the cap off loosen the nut and turn the stud with a screwdriver to adjust your set pressure then once you get it where you want it tighten the nut back up. i bumped my preasure up for a couple reasons one of them was for airing up tires as well.
  10. Ruthless
    Ruthless Road Train Member
    9,096
    90,224
    Aug 28, 2010
    The City.
    Internal gears match right up?
  11. rollin coal
    rollin coal Road Train Member
    13,457
    27,453
    Mar 29, 2008
    TN
    My compressor has 2 cylinders it was replaced when the motor was inframed. You'd think it'd air up quick with 2 cylinders but it never has.
