Replacing gauge cluster bulbs . 2003 columbia
Discussion in 'Ask An Owner Operator' started by henboy1, Feb 5, 2020.
  1. henboy1
    henboy1 Medium Load Member
    331
    139
    Mar 26, 2011
    stockbridge
    My speedometer and rpm light does not come on . I can replace the air gauges without removing the dash cover over there . How about the light behind the gauge cluster? Is the bulb directly behind those 2 clusters ? I took the clear lid off both of them , but I stopped when I saw the needle in the way . Thx
  3. spyder7723
    spyder7723 Road Train Member
    15,471
    25,075
    Mar 31, 2013
    sarasota, fl
    Gotta pull the cluster, but it's really easy. Need ti remove the trim piece above it, and the dash panels on each side, then tilt thr steering column differen and it will tilt down enough to access all the bulbs in the back. Leave the clear plastic cover on it so you don't risk breaking the gauge needles.
    baha, henboy1 and Deere hunter Thank this.
  4. henboy1
    331
    139
    Mar 26, 2011
    stockbridge
    Thx . Great info
  5. buddyd157
    buddyd157 Road Train Member
    13,564
    34,840
    May 25, 2017
    under a shade tree
    if you're not going to replace all the bulbs, i'd recommend that you do replace all of them. when one burns out, it's only a matter of time before they all start burning out, as they are all the same age.
    henboy1 Thanks this.
